Witch Magic, Snake Oil Medicine, and Spatial Index Tuning
5459
07-07-2015 11:10 AM
ThomasColson
10 2 5,459
There are about as many opinions and resources on SQL Spatial Index Tuning as there are on why the use of a Sequential GUID is good or bad. There's The Black Art Of Spatial Index Tuning In SQL Server | boomphisto , ArcGIS Help 10.1, Spatial Indexing Overview , Spatial Indexing: From 4 Days to 4 Hours - CSS SQL Server Engineers - Site Home - MSDN Blogs, sp_help_spatial_geography_histogram and Indexing geography data in SQL Server Denali | Alastair Aitc... , Basic Multi-Level Grids - Isaac @ MSDN - Site Home - MSDN Blogs , http://social.technet.microsoft.com/wiki/contents/articles/9694.tuning-spatial-point-data-queries-in... ,  and of course, if you've ever struggled with a poorly-performing spatial index and posted about it on the internet, chances are you got a reply from this guy.
Unfortunately, most of us are not database programmers, nor do we dream in SQL syntax. SQL is like learning French by reading a Chinese dictionary. I don't know about you, but I can't make heads or tails of one single line of SQL code. I'm happy to copy other peoples SQL snippets and hack them up 'till I get them to work. I particularly love this statement from ArcGIS Help: "If you create your data through ArcGIS for Desktop, the spatial grid index is calculated for you." That's like saying "If you put your key in the ignition, your car will drive to the store, get milk, and NOT kill a raccoon on the way". Unless your a Massachusetts driver, there are obviously a few things you have to tweak, such as turn the steering wheel and press the gas paddle in endlessly unique combinations in order to get to the milk store and swerve to avoid the raccoon. The same goes for SQL Spatial Indexes in a SDE Database. Just because the software enables them out of the box by no means implies that the index is optimized for your particular data environment.
Out of the box, ArcGIS creates a spatial index with 16 Cells Per Object with all four levels set to Medium Grid Levels.
Notice how the storage type is Goemetry, which some of you are discovering is the "New" ESRI default storage format.
Let's see how the "Out of the Box" spatial index performs. One way to test a spatial index "Quick and Easy" is with the Spatial Index Stored Procedures.
CREATE SPATIAL INDEX
--THIS IS THE DEFAULT NAME OF THE INDEX
--CREATED BY ARCGIS
[S1169_idx]
ON
--AND THIS IS THE NAME OF TABLE
--SUPPLIED BY THE USER IN ARCGIS
--AT CREATION TIME
[dbo].[TEST_GEOM]
  [SHAPE]
)USING  GEOMETRY_GRID
WITH (BOUNDING_BOX =(227166.13, 3925740.74, 314851.6915, 3968047.64),
GRIDS =(
LEVEL_1 = MEDIUM,
LEVEL_2 = MEDIUM,
LEVEL_3 = MEDIUM,
LEVEL_4 = MEDIUM),
CELLS_PER_OBJECT = 16, PAD_INDEX = OFF, STATISTICS_NORECOMPUTE = OFF, SORT_IN_TEMPDB = OFF,
--DROP_EXISTING = ON ALLOWS US TO DO THIS ALL
--DAY WITHOUT MESSING WITH DROPPING THE IDX
DROP_EXISTING = ON,
ONLINE = OFF, ALLOW_ROW_LOCKS = ON, ALLOW_PAGE_LOCKS = ON, FILLFACTOR = 100) ON [PRIMARY]
GO
DECLARE @geom geometry
--THE POLYGON IS AN AREA SMALLER THAN THE BOUNDING BOX
SET @geom = GEOMETRY::STGeomFromText('POLYGON ((247804.201 3943957.896, 29932.568 3943963.210, 247671.344 3942876.441, 247684.630 3943652.325,247804.201 3943957.896))', 26917)jjj
exec sp_help_spatial_geometry_index 'TEST_GEOM', 'S1169_idx', 1, @geom
There's a WHOLE lot of output. The first thing my eye spies is
Primary_Filter_Efficiency19.634703196347
and
Internal_Filter_Efficiency0
I'm no expert on SQL or spatial indexes, but I don't think those numbers look good. No wonder my draw times are slow, spatial queries are sluggish, and in general, the database is performing horribly. Every single ArcGIS-created table has the same index parameters!
Just for giggle, lets change the cells per object by altering just this in the above code snippet:
CELLS_PER_OBJECT = 4096
And look at the increase in efficiencies!
Internal_Filter_Efficiency76.7441860465116
91.4893617021277
Again, I'm claiming to be no expert at SQL Spatial Index Tuning, but I think I'm on to something here. As it turns out, my test data consists of "Very Complex Line Strings", which, if you're not living under the GIS rock, that's what all of your data is. Coincidentally, using value of 8192 for Cells Per Object in this scenario is a good starting point.
But there's a lot (lots and lots) of values between 16 and 8092, and then there's all the permutations of Low, Medium, and High that could be tested to determine the spatial index that is likely to give you the best performance most of the time. What if there was a way to automatically test spatial index settings and magically determine which parameters best fit your data scenario?
Enter the SDE Hacker....
I stumbled across this geospatial - Selecting a good SQL Server 2008 spatial index with large polygons - Stack Overflow  post where someone had posted a SQL stored procedure that will loop through Cell Sizes and Grid Levels to report Spatial Query results for every permutation (user supplied). Being the tinker that I am, I of course broke the code trying to add a bunch of output. Finally got it working. Here it is:
--ORIGINAL SQL CODE FROM
--http://stackoverflow.com/users/2250424/greengeo
--MODIFIFIED TO INCLUDE SPATIAL INDEX HELP OUTPUT
--IN TABLE
  --LOOK FOR THE EXCLAMATION POINTS IN THIS CODE
  --THERE ARE SEVERAL USER-SUPPLIED VARIABLES THAT MUST
  --BE INPUT FOR THIS SP TO WORK
USE DATBASE
GO
CREATE PROCEDURE dbo.sp_tune_spatial_index
  @tabnm VARCHAR(MAX), -- This parameter stores the name of the spatial table for which you are tuning the index
  @idxnm VARCHAR(MAX), -- This parameter stores the name of the spatial index of the named table
  @min_cells_per_obj INT, -- Minimum Cells Per Object to test on. Suggested to start at 2.
  @max_cells_per_obj INT, -- Maximum Cells Per Object to test on.
  /* The test requires two geometry instances to use in test query 1 and 2.
  The first one should cover the area of default extent. The second should
  cover an area roughly the size of the area shown when zoomed in, panning
  around. It is required that the variable store a string that will create
  the geometry instance since this will be done within the procedure and
  cannot be a variable of type: GEOMETRY. The SRID of these instances must
  match that of the table you are testing. */
  @testgeom1 VARCHAR(MAX), -- This parameter stores the first geometry instance creation string that will be used in the test
  @testgeom2 VARCHAR(MAX) -- This parameter stores the second geometry instance creation string that will be used in the test
AS
SET NOCOUNT ON;
/* Prior to running this procedure, two tables are required. These tables are
  created here to prepare for running the procedure. */
PRINT 'Checking for required tables...'
IF EXISTS(SELECT 1 FROM sysobjects WHERE name IN ('cell_opt_perm', 'spat_idx_test_result'))
  BEGIN
  PRINT '... The "cell_opt_perm" and "spat_idx_test_result" tables exist.'
  END
ELSE
BEGIN
  PRINT '... Creating "cell_opt_perm" and "spat_idx_test_result" tables.'
  CREATE TABLE cell_opt_perm(
  [perm_id] [smallint] NOT NULL,
  [permutation] [nvarchar](4) NOT NULL,
  [level1] [nvarchar](6) NOT NULL,
  [level2] [nvarchar](6) NOT NULL,
  [level3] [nvarchar](6) NOT NULL,
  [level4] [nvarchar](6) NOT NULL
  INSERT INTO cell_opt_perm ([perm_id], [permutation], [level1], [level2], [level3], [level4])
  VALUES (1,'LLLL','LOW','LOW','LOW','LOW'),
  (2,'LLLM','LOW','LOW','LOW','MEDIUM'),
  (3,'LLLH','LOW','LOW','LOW','HIGH'),
  (4,'LLML','LOW','LOW','MEDIUM','LOW'),
  (5,'LLMM','LOW','LOW','MEDIUM','MEDIUM'),
  (6,'LLMH','LOW','LOW','MEDIUM','HIGH'),
  (7,'LLHL','LOW','LOW','HIGH','LOW'),
  (8,'LLHM','LOW','LOW','HIGH','MEDIUM'),
  (9,'LLHH','LOW','LOW','HIGH','HIGH'),
  (10,'LMLL','LOW','MEDIUM','LOW','LOW'),
  (11,'LMLM','LOW','MEDIUM','LOW','MEDIUM'),
  (12,'LMLH','LOW','MEDIUM','LOW','HIGH'),
  (13,'LMML','LOW','MEDIUM','MEDIUM','LOW'),
  (14,'LMMM','LOW','MEDIUM','MEDIUM','MEDIUM'),
  (15,'LMMH','LOW','MEDIUM','MEDIUM','HIGH'),
  (16,'LMHL','LOW','MEDIUM','HIGH','LOW'),
  (17,'LMHM','LOW','MEDIUM','HIGH','MEDIUM'),
  (18,'LMHH','LOW','MEDIUM','HIGH','HIGH'),
  (19,'LHLL','LOW','HIGH','LOW','LOW'),
  (20,'LHLM','LOW','HIGH','LOW','MEDIUM'),
  (21,'LHLH','LOW','HIGH','LOW','HIGH'),
  (22,'LHML','LOW','HIGH','MEDIUM','LOW'),
  (23,'LHMM','LOW','HIGH','MEDIUM','MEDIUM'),
  (24,'LHMH','LOW','HIGH','MEDIUM','HIGH'),
  (25,'LHHL','LOW','HIGH','HIGH','LOW'),
  (26,'LHHM','LOW','HIGH','HIGH','MEDIUM'),
  (27,'LHHH','LOW','HIGH','HIGH','HIGH'),
  (28,'MLLL','MEDIUM','LOW','LOW','LOW'),
  (29,'MLLM','MEDIUM','LOW','LOW','MEDIUM'),
  (30,'MLLH','MEDIUM','LOW','LOW','HIGH'),
  (31,'MLML','MEDIUM','LOW','MEDIUM','LOW'),
  (32,'MLMM','MEDIUM','LOW','MEDIUM','MEDIUM'),
  (33,'MLMH','MEDIUM','LOW','MEDIUM','HIGH'),
  (34,'MLHL','MEDIUM','LOW','HIGH','LOW'),
  (35,'MLHM','MEDIUM','LOW','HIGH','MEDIUM'),
  (36,'MLHH','MEDIUM','LOW','HIGH','HIGH'),
  (37,'MMLL','MEDIUM','MEDIUM','LOW','LOW'),
  (38,'MMLM','MEDIUM','MEDIUM','LOW','MEDIUM'),
  (39,'MMLH','MEDIUM','MEDIUM','LOW','HIGH'),
  (40,'MMML','MEDIUM','MEDIUM','MEDIUM','LOW'),
  (41,'MMMM','MEDIUM','MEDIUM','MEDIUM','MEDIUM'),
  (42,'MMMH','MEDIUM','MEDIUM','MEDIUM','HIGH'),
  (43,'MMHL','MEDIUM','MEDIUM','HIGH','LOW'),
  (44,'MMHM','MEDIUM','MEDIUM','HIGH','MEDIUM'),
  (45,'MMHH','MEDIUM','MEDIUM','HIGH','HIGH'),
  (46,'MHLL','MEDIUM','HIGH','LOW','LOW'),
  (47,'MHLM','MEDIUM','HIGH','LOW','MEDIUM'),
  (48,'MHLH','MEDIUM','HIGH','LOW','HIGH'),
  (49,'MHML','MEDIUM','HIGH','MEDIUM','LOW'),
  (50,'MHMM','MEDIUM','HIGH','MEDIUM','MEDIUM'),
  (51,'MHMH','MEDIUM','HIGH','MEDIUM','HIGH'),
  (52,'MHHL','MEDIUM','HIGH','HIGH','LOW'),
  (53,'MHHM','MEDIUM','HIGH','HIGH','MEDIUM'),
  (54,'MHHH','MEDIUM','HIGH','HIGH','HIGH'),
  (55,'HLLL','HIGH','LOW','LOW','LOW'),
  (56,'HLLM','HIGH','LOW','LOW','MEDIUM'),
  (57,'HLLH','HIGH','LOW','LOW','HIGH'),
  (58,'HLML','HIGH','LOW','MEDIUM','LOW'),
  (59,'HLMM','HIGH','LOW','MEDIUM','MEDIUM'),
  (60,'HLMH','HIGH','LOW','MEDIUM','HIGH'),
  (61,'HLHL','HIGH','LOW','HIGH','LOW'),
  (62,'HLHM','HIGH','LOW','HIGH','MEDIUM'),
  (63,'HLHH','HIGH','LOW','HIGH','HIGH'),
  (64,'HMLL','HIGH','MEDIUM','LOW','LOW'),
  (65,'HMLM','HIGH','MEDIUM','LOW','MEDIUM'),
  (66,'HMLH','HIGH','MEDIUM','LOW','HIGH'),
  (67,'HMML','HIGH','MEDIUM','MEDIUM','LOW'),
  (68,'HMMM','HIGH','MEDIUM','MEDIUM','MEDIUM'),
  (69,'HMMH','HIGH','MEDIUM','MEDIUM','HIGH'),
  (70,'HMHL','HIGH','MEDIUM','HIGH','LOW'),
  (71,'HMHM','HIGH','MEDIUM','HIGH','MEDIUM'),
  (72,'HMHH','HIGH','MEDIUM','HIGH','HIGH'),
  (73,'HHLL','HIGH','HIGH','LOW','LOW'),
  (74,'HHLM','HIGH','HIGH','LOW','MEDIUM'),
  (75,'HHLH','HIGH','HIGH','LOW','HIGH'),
  (76,'HHML','HIGH','HIGH','MEDIUM','LOW'),
  (77,'HHMM','HIGH','HIGH','MEDIUM','MEDIUM'),
  (78,'HHMH','HIGH','HIGH','MEDIUM','HIGH'),
  (79,'HHHL','HIGH','HIGH','HIGH','LOW'),
  (80,'HHHM','HIGH','HIGH','HIGH','MEDIUM'),
  (81,'HHHH','HIGH','HIGH','HIGH','HIGH')
  CREATE TABLE spat_idx_test_result(
  [perm_id] [int] NOT NULL,
  [num_cells] [int] NOT NULL,
  [permut] [nvarchar](4) NOT NULL,
  [g1t1] [bigint] NULL,
  [g1t2] [bigint] NULL,
  [g1t3] [bigint] NULL,
  [g1t4] [bigint] NULL,
  [g2t1] [bigint] NULL,
  [g2t2] [bigint] NULL,
  [g2t3] [bigint] NULL,
  [g2t4] [bigint] NULL,
  [PF_EFF][float] NULL,
  [IF_EFF][float] NULL,
  [GRIDL1] [int] NULL,
  [GRIDL2] [int] NULL,
  [GRIDL3] [int] NULL,
  [GRIDL4] [int] NULL,
  [TPIR] [bigint] NULL,
  [TPIP] [bigint] NULL,
  [ANOIRPBR] [bigint] NULL,
  [TNOOCILFQ] [bigint] NULL,
  [TNOOCIL3FQ] [bigint] NULL,
  [TNOOCIL4FQ] [bigint] NULL,
  [TNOOCIL0II] [bigint] NULL,
  [TNOOCIL4II] [bigint] NULL,
  [TNOIOIL3FQ] [bigint] NULL,
  [TNOIOIL4FQ] [bigint] NULL,
     [ITTCNTLGP] [float] NULL,
  [INTTTCNTLGP] [float] NULL,
  [BTTCNTLGP] [float] NULL,
  [ACPONTLGP] [float] NULL,
  [AOPG] [float] NULL,
  [NORSBPF] [bigint] NULL,
  [NORSBIF] [bigint] NULL,
  [NOTSFIC] [bigint] NULL,
  [NORO] [bigint] NULL,
  [PORNBPF] [float] NULL,
  [POPFRSBIF] [float] NULL
  INSERT INTO dbo.spat_idx_test_result
  VALUES (0,16,0,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL)
END
/* delete all rows from "spat_idx_test_result" table. This makes it ready to stuff in new results.
  !!!WARNING!!! if your test was interupted, the table will be cleared out and the test will
  begin from the beginning. You could try to modify this to start where you left off but
  I didn't have time and this worked well enough for me. */
DELETE FROM spat_idx_test_result
  WHERE perm_id != 0
/* set up counters */
DECLARE @a1 INT
DECLARE @a2 INT
DECLARE @a3 INT
DECLARE @a4 INT
/* set up variables to hold high/medium/low values and permutation to use in rebuilding
   the spatial index and recording stats */
DECLARE @lev1 VARCHAR(6)
DECLARE @lev2 VARCHAR(6)
DECLARE @lev3 VARCHAR(6)
DECLARE @lev4 VARCHAR(6)
DECLARE @permut VARCHAR(6)
DECLARE @num_cell VARCHAR(4)
DECLARE @time_str VARCHAR(20)
DECLARE @perm_id VARCHAR(20)
DECLARE @x xml
DECLARE @pf_eff FLOAT
/* create variables to hold timestamps for beginning and ending of test queries */
DECLARE @start_t DATETIME
DECLARE @end_t DATETIME
DECLARE @elapse_t INT
/* begin looping through cell option permutations */
SET @a1 = @min_cells_per_obj
WHILE @a1 <= @max_cells_per_obj
  BEGIN
  SET @a2 = 1
  PRINT 'Started Testing for ' +CAST(@a1 AS VARCHAR(10)) +' cells per object'
  WHILE @a2 < 82
  BEGIN
  SELECT @lev1 = level1, @lev2 = level2, @lev3 = level3, @lev4 = level4 FROM cell_opt_perm WHERE perm_id = @a2
  SET @permut = '''' +(SELECT permutation FROM cell_opt_perm WHERE perm_id = @a2) +''''
  EXEC
  CREATE SPATIAL INDEX ' +@idxnm +' ON ' +@tabnm +'
  [SHAPE]
  USING  GEOMETRY_GRID
  WITH
  --MAKE SURE YOU EDIT THE BOUNDING BOX TO BE EXACTLY EQUAL TO THE BOUNDING
  --BOX OF YOUR SPATIAL TABLE
  GRIDS =(LEVEL_1 = ' +@lev1 +' ,LEVEL_2 = ' +@lev2 +' ,LEVEL_3 = ' +@lev3 +' ,LEVEL_4 = ' +@lev4 +' ),
  CELLS_PER_OBJECT = ' +@a1 +' ,
  PAD_INDEX  = OFF,
  DROP_EXISTING = ON,
  FILLFACTOR = 100
  ON [PRIMARY]
  PRINT 'Re-built index to ' +@permut
  SET @a3 = 1
  SET @a4 = 1
  WHILE @a3 < 5
  BEGIN
  SET @start_t = GETDATE()
  EXEC
  'CREATE TABLE #tmp_tab (shp GEOMETRY)
  DECLARE @g1 GEOMETRY
  SET @g1 = ' +@testgeom1 +'
  INSERT #tmp_tab (shp)
  SELECT
  r.Shape AS shp
  FROM
  ' +@tabnm +' r
  WHERE
  r.SHAPE.STIntersects(@g1) = 1
  DROP TABLE #tmp_tab'
  SET @end_t = GETDATE()
  SET @elapse_t = (SELECT DATEDIFF(MS, @start_t, @end_t))
  SET @num_cell = CAST(@a1 AS VARCHAR(6))
  SET @time_str = CAST(@elapse_t AS VARCHAR(20))
  IF @a3 = 1
  BEGIN
  IF (SELECT TOP 1 perm_id FROM spat_idx_test_result) IS NULL
  BEGIN
  SET @perm_id = 1
  END
  ELSE
  BEGIN
  SET @perm_id = CAST((SELECT MAX(perm_id+1) FROM spat_idx_test_result) AS VARCHAR(20))
  END
  EXEC
  INSERT INTO spat_idx_test_result (perm_id, num_cells, permut, g1t' +@a3 +')
  VALUES (' +@perm_id +', ' +@num_cell +', ' +@permut +', ' +@time_str +')'
  END
  ELSE
  EXEC
  UPDATE spat_idx_test_result
  SET
  num_cells = ' +@num_cell +',
  permut = ' +@permut +',
  g1t' +@a3 +' = ' +@time_str +'
  WHERE perm_id = ' +@perm_id
  SET @a3 = @a3 + 1
  END
  WHILE @a4 < 5
  BEGIN
  EXEC
  DECLARE @g2 GEOMETRY
  SET @g2 = ' +@testgeom2 +'
  SELECT
  r.Shape AS shp
  FROM
  ' +@tabnm +' r
  WHERE
  r.SHAPE.STIntersects(@g2) = 1
  EXEC
  DECLARE @x xml
  DECLARE @PFVALUE float
  DECLARE @IFVALUE float
  DECLARE @GRIDL1VALUE int
  DECLARE @GRIDL2VALUE int
  DECLARE @GRIDL3VALUE int
  DECLARE @GRIDL4VALUE int
  DECLARE @TPIRVALUE bigint
  DECLARE @TPIPVALUE bigint
  DECLARE @ANOIRPBRVALUE bigint
  DECLARE @TNOOCILFQVALUE bigint
  DECLARE @TNOOCIL0IIVALUE bigint
  DECLARE @TNOOCIL4IIVALUE bigint
  DECLARE @TNOOCIL3FQVALUE bigint
  DECLARE @TNOOCIL4FQVALUE bigint
  DECLARE @TNOIOIL3FQVALUE bigint
  DECLARE @TNOIOIL4FQVALUE bigint
  DECLARE @ITTCNTLGPVALUE float
  DECLARE @INTTTCNTLGPVALUE float
  DECLARE @BTTCNTLGPVALUE float
  DECLARE @ACPONTLGPVALUE float
  DECLARE @AOPGVALUE float
  DECLARE @NORSBPFVALUE bigint
  DECLARE @NORSBIFVALUE bigint
  DECLARE @NOTSFICVALUE bigint
  DECLARE @NOROVALUE bigint
  DECLARE @PORNBPFVALUE float
  DECLARE @POPFRSBIFVALUE float
  --MAKE SURE YOU EDIT GEOMETRY VARIABLE BELOW TO REPRESENT A POLYGON
  --THAT IS WITHIN YOUR BOUNDING BOX
  SET @geom = GEOMETRY::STGeomFromText(''POLYGON ((247804.201 3943957.896, 29932.568 3943963.210, 247671.344 3942876.441, 247684.630 3943652.325,247804.201 3943957.896))'', 26917)
  --MAKE SURE YOU SPECIFY THE NAME OF YOUR SPATIAL TABLE
  --AND THE NAME OF THE SPATIAL INDEX
  -- IN THE sp_help_spatial_geometry_index_xml VARIABLES
  exec sp_help_spatial_geometry_index_xml TEST_GEOM , S1169_idx , 1, @geom, @x output
  SET @PFVALUE =  @x.value(''(/Primary_Filter_Efficiency/text())[1]'', ''float'')
  SET @IFVALUE =  @x.value(''(/Internal_Filter_Efficiency/text())[1]'', ''float'')
  SET @GRIDL1VALUE =  @x.value(''(/Grid_Size_Level_1/text())[1]'', ''int'')
  SET @GRIDL2VALUE =  @x.value(''(/Grid_Size_Level_2/text())[1]'', ''int'')
  SET @GRIDL3VALUE =  @x.value(''(/Grid_Size_Level_3/text())[1]'', ''int'')
  SET @GRIDL4VALUE =  @x.value(''(/Grid_Size_Level_4/text())[1]'', ''int'')
  SET @TPIRVALUE =  @x.value(''(/Total_Primary_Index_Rows/text())[1]'', ''bigint'')
  SET @TPIPVALUE =  @x.value(''(/Total_Primary_Index_Pages/text())[1]'', ''bigint'')
  SET @ANOIRPBRVALUE =  @x.value(''(/Average_Number_Of_Index_Rows_Per_Base_Row/text())[1]'', ''bigint'')
  SET @TNOOCILFQVALUE =  @x.value(''(/Total_Number_Of_ObjectCells_In_Level0_For_QuerySample/text())[1]'', ''bigint'')
  SET @TNOOCIL0IIVALUE =  @x.value(''(/Total_Number_Of_ObjectCells_In_Level0_In_Index/text())[1]'', ''bigint'')
  SET @TNOOCIL4IIVALUE =  @x.value(''(/Total_Number_Of_ObjectCells_In_Level4_In_Index/text())[1]'', ''bigint'')
  SET @TNOOCIL3FQVALUE =  @x.value(''(/Total_Number_Of_ObjectCells_In_Level3_For_QuerySample/text())[1]'', ''bigint'')
  SET @TNOOCIL4FQVALUE =  @x.value(''(/Total_Number_Of_ObjectCells_In_Level4_For_QuerySample/text())[1]'', ''bigint'')
  SET @TNOIOIL3FQVALUE =  @x.value(''(/Total_Number_Of_Interior_ObjectCells_In_Level3_For_QuerySample/text())[1]'', ''bigint'')
  SET @TNOIOIL4FQVALUE =  @x.value(''(/Total_Number_Of_Interior_ObjectCells_In_Level4_For_QuerySample/text())[1]'', ''bigint'')
  SET @ITTCNTLGPVALUE =  @x.value(''(/Interior_To_Total_Cells_Normalized_To_Leaf_Grid_Percentage/text())[1]'', ''float'')
  SET @INTTTCNTLGPVALUE =  @x.value(''(/Intersecting_To_Total_Cells_Normalized_To_Leaf_Grid_Percentage/text())[1]'', ''float'')
  SET @BTTCNTLGPVALUE =  @x.value(''(/Border_To_Total_Cells_Normalized_To_Leaf_Grid_Percentage/text())[1]'', ''float'')
  SET @ACPONTLGPVALUE =  @x.value(''(/Average_Cells_Per_Object_Normalized_To_Leaf_Grid/text())[1]'', ''float'')
  SET @AOPGVALUE =  @x.value(''(/Average_Objects_PerLeaf_GridCell/text())[1]'', ''float'')
  SET @NORSBPFVALUE =  @x.value(''(/Number_Of_Rows_Selected_By_Primary_Filter/text())[1]'', ''bigint'')
  SET @NORSBIFVALUE =  @x.value(''(/Number_Of_Rows_Selected_By_Internal_Filter/text())[1]'', ''bigint'')
  SET @NOTSFICVALUE =  @x.value(''(/Number_Of_Times_Secondary_Filter_Is_Called/text())[1]'', ''bigint'')
  SET @NOROVALUE =  @x.value(''(/Number_Of_Rows_Output/text())[1]'', ''bigint'')
  SET @PORNBPFVALUE =  @x.value(''(/Percentage_Of_Rows_NotSelected_By_Primary_Filter/text())[1]'', ''float'')
  SET @POPFRSBIFVALUE =  @x.value(''(/Percentage_Of_Primary_Filter_Rows_Selected_By_Internal_Filter/text())[1]'', ''float'')
  SET
  g2t' +@a4 +' = ' +@time_str +',
  PF_EFF = @PFVALUE,
  IF_EFF = @IFVALUE,
  GRIDL1 = @GRIDL1VALUE,
  GRIDL2 = @GRIDL2VALUE,
  GRIDL3 = @GRIDL3VALUE,
  GRIDL4 = @GRIDL4VALUE,
  TPIR = @TPIRVALUE,
  TPIP = @TPIPVALUE,
  ANOIRPBR = @ANOIRPBRVALUE,
  TNOOCILFQ = @TNOOCILFQVALUE,
  TNOOCIL0II = @TNOOCIL0IIVALUE,
  TNOOCIL4II = @TNOOCIL4IIVALUE,
  TNOOCIL3FQ =  @TNOOCIL3FQVALUE,
  TNOOCIL4FQ =  @TNOOCIL4FQVALUE,
  TNOIOIL3FQ = @TNOIOIL3FQVALUE,
  TNOIOIL4FQ = @TNOIOIL4FQVALUE,
  ITTCNTLGP = @ITTCNTLGPVALUE,
  INTTTCNTLGP = @INTTTCNTLGPVALUE,
  BTTCNTLGP = @BTTCNTLGPVALUE,
  ACPONTLGP = @ACPONTLGPVALUE,
  AOPG = @AOPGVALUE,
  NORSBPF = @NORSBPFVALUE,
  NORSBIF = @NORSBIFVALUE,
  NOTSFIC = @NOTSFICVALUE,
  NORO = @NOROVALUE,
  PORNBPF = @PORNBPFVALUE,
  POPFRSBIF = @POPFRSBIFVALUE
  SET @a4 = @a4 + 1
  END
  SET @a2 = @a2 + 1
  END
  SET @a1 = @a1 + 1
  END
PRINT 'Testing of ' +@tabnm +' spatial index: ' +@idxnm +' is complete!'
GO
The hacking that I did involved using the xml output of the index help stored procedure to write some more descriptive results to the output in addition to query time.
The stored procedure is executed like so:
DECLARE @BOUNDING VARCHAR(MAX)
SET @BOUNDING = 'GEOMETRY::STGeomFromText(''POLYGON ((226805.072 3975572.527, 318101.215 3975985.165, 317894.896 3922239.073, 225360.839  3926571.772 , 226805.072 3975572.527))'', 0)'
DECLARE @QUERY VARCHAR(MAX)
SET @QUERY = 'GEOMETRY::STGeomFromText(''POLYGON ((247804.201 3943957.896, 29932.568 3943963.210, 247671.344 3942876.441, 247684.630 3943652.325, 247804.201 3943957.896))'', 26917)'
EXEC sp_tune_spatial_index 'TEST_GEOM', 'S1169_idx', 4096, 4096, @BOUNDING, @QUERY
GO
In this example I'm only testing one Cell Size: 4096, but you could use any value range such as 8, 16.
Results can be nicely reviewed with the following:
SELECT
    perm_id as 'Permutation #'
      ,num_cells 'Cells Per Object'
      ,permut as 'Grids'
      ,g1t1 as 'ms to query entire geometry (Level 1)'
      ,g1t2 as 'ms to query entire geometry (Level 2)'
      ,g1t3 as 'ms to query entire geometry (Level 3)'
      ,g1t4 as 'ms to query entire geometry (Level 4)'
      ,g2t1 as 'ms to execute spatial query (Level 1)'
      ,g2t2 as 'ms to execute spatial query (Level 2)'
      ,g2t3 as 'ms to execute spatial query (Level 3)'
      ,g2t4 as 'ms to execute spatial query (Level 4)'
      ,PF_EFF as 'Primary Filter Efficiency'
      ,IF_EFF as 'Internal Filter Efficiency'
      ,GRIDL1 as 'Grid Size Level 1'
      ,GRIDL2 as 'Grid Size Level 2'
      ,GRIDL3 as 'Grid Size Level 3'
      ,GRIDL4 as 'Grid Size Level 4'
      ,TPIR as 'Total Primary Index Rows'
      ,TPIP as 'Total Primary Index Pages'
      ,ANOIRPBR as 'Average Number of Index Rows Per Base Row'
      ,TNOOCILFQ as 'Total Number of Object Cells in Level 0 For Query Sample'
   ,TNOOCIL3FQ as 'Total Number of Object Cells in Level 3 For Query Sample'
   ,TNOOCIL4FQ as 'Total Number of Object Cells in Level 4 For Query Sample'
      ,TNOOCIL0II as 'Total Number of Object Cells In Level 0 In Index'
      ,TNOOCIL4II as 'Total Number of Object Cells In Level 4 In Index'
   ,TNOIOIL3FQ as 'Total Number Of Interior ObjectCells In Level 3 For QuerySample'
   ,TNOIOIL4FQ as 'Total Number Of Interior ObjectCells In Level 4 For QuerySample'
   ,ITTCNTLGP as 'Interior To Total Cells Normalized To Leaf Grid Percentage'
   ,INTTTCNTLGP as 'Intersecting To Total Cells Normalized To Leaf Grid Percentage'
   ,BTTCNTLGP as 'Border To Total Cells Normalized To Leaf Grid Percentage'
   ,ACPONTLGP as 'Average Cells Per Object Normalized To Leaf Grid'
   ,AOPG as 'Average Objects PerLeaf GridCell'
   ,NORSBPF as 'Number Of Rows Selected By Primary Filter'
   ,NORSBIF as 'Number Of Rows Selected By Internal Filter'
   ,NOTSFIC as 'Number Of Times Secondary Filter Is Called'
   ,NORO as 'Number Of Rows Output'
   ,PORNBPF as 'Percentage Of Rows NotSelected By Primary Filter'
   ,POPFRSBIF as 'Percentage Of Primary Filter Rows Selected By Internal Filter'
ORDER BY PF_EFF
Permutation #Cells Per ObjectGridsms to query entire geometry (Level 1)ms to query entire geometry (Level 2)ms to query entire geometry (Level 3)ms to query entire geometry (Level 4)ms to execute spatial query (Level 1)ms to execute spatial query (Level 2)ms to execute spatial query (Level 3)ms to execute spatial query (Level 4)Primary Filter EfficiencyInternal Filter EfficiencyGrid Size Level 1Grid Size Level 2Grid Size Level 3Grid Size Level 4Total Primary Index RowsTotal Primary Index PagesAverage Number of Index Rows Per Base RowTotal Number of Object Cells in Level 0 For Query SampleTotal Number of Object Cells in Level 3 For Query SampleTotal Number of Object Cells in Level 4 For Query SampleTotal Number of Object Cells In Level 0 In IndexTotal Number of Object Cells In Level 4 In IndexTotal Number Of Interior ObjectCells In Level 3 For QuerySampleTotal Number Of Interior ObjectCells In Level 4 For QuerySampleInterior To Total Cells Normalized To Leaf Grid PercentageIntersecting To Total Cells Normalized To Leaf Grid PercentageBorder To Total Cells Normalized To Leaf Grid PercentageAverage Cells Per Object Normalized To Leaf GridAverage Objects PerLeaf GridCellNumber Of Rows Selected By Primary FilterNumber Of Rows Selected By Internal FilterNumber Of Times Secondary Filter Is CalledNumber Of Rows OutputPercentage Of Rows NotSelected By Primary FilterPercentage Of Primary Filter Rows Selected By Internal Filter
0160NULLNULLNULLNULLNULLNULLNULLNULLNULLNULLNULLNULLNULLNULLNULLNULLNULLNULLNULLNULLNULLNULLNULLNULLNULLNULLNULLNULLNULLNULLNULLNULLNULLNULLNULL
64096LLMH906670664616302368.253968253968369.76744186046511616642562127866101110398322127672355989.354757720311310.56992216921920.07532011046949542.04256410256410.489580718051726330334396.769230769230847.6190476190476
704096HMHL1561361301465033363368.253968253968369.7674418604651256642561679767239401398062797653559NULL000006330334396.769230769230847.6190476190476
714096HMHM2332262031664340406668.253968253968369.767441860465125664256641574324728013980521574103559NULL000006330334396.769230769230847.6190476190476
724096HMHH3763102632665363735668.253968253968369.76744186046512566425625630661191515713981523061763559NULL000006330334396.769230769230847.6190476190476
524096MHHL1561161331404633434068.253968253968369.7674418604651642562561679767239401398062797653559NULL000006330334396.769230769230847.6190476190476
534096MHHM2432162101864343433368.253968253968369.767441860465164256256641574324728013980521574103559NULL000006330334396.769230769230847.6190476190476
544096MHHH3662562632665643565068.253968253968369.76744186046516425625625630661191515713981523061763559NULL000006330334396.769230769230847.6190476190476
304096MLLH866370664026302068.253968253968369.76744186046516416162562127866101102399422127672342985.853780671006514.071106659990.07511266900350532.048205128205130.4882323485227846330334396.769230769230847.6190476190476
124096LMLH837363634323262070.491803278688572.0930232558139166416256212786610195399922127672333183.29582395598916.62915728932230.07501875468867222.050769230769230.4876219054763696131304396.871794871794950.8196721311475
264096LHHM1561401431405040403078.181818181818241.86046511627911625625664797672394014008772797653576NULL000005518374397.179487179487232.7272727272727
274096LHHH1531431701635636463078.181818181818241.86046511627911625625625615743247280140137221574203576NULL000005518374397.179487179487232.7272727272727
254096LHHL1168683804336403378.181818181818241.86046511627911625625616407691232013996902407673576NULL99.84294838236830.1553065996579760.0017450179736851329.38769230769230.034027850486865518374397.179487179487232.7272727272727
434096MMHL766363633330403378.181818181818241.86046511627916464256164076912320140038324076735762428.915662650602469.87951807228921.204819277108430.042564102564102623.49397590361455518374397.179487179487232.7272727272727
444096MMHM1531431331264340433078.181818181818241.8604651162791646425664797672394014008772797653576NULL000005518374397.179487179487232.7272727272727
454096MMHH2332232231764340503078.181818181818241.8604651162791646425625615743247280140137221574203576NULL000005518374397.179487179487232.7272727272727
394096MMLH1069690964320332084.313725490196174.4186046511628646416256407691232013323749240767229335589.49053080821559.895972259269140.6134969325153371.92256410256410.5201387036543085132194397.384615384615462.7450980392157
334096MLMH1109390964320332684.313725490196174.4186046511628641664256407691232014253669240767325322787.953120741346411.42000545107660.6268738075769961.881538461538460.5314799672935415132194397.384615384615462.7450980392157
794096HHHL2462061731764640462684.313725490196174.4186046511628256256256161574334728013667NULL21573863291NULL25.067362347542174.92502070856620.00761694389168706107.7220512820510.00928315036799365132194397.384615384615462.7450980392157
804096HHHM3803502932464343464684.313725490196174.41860465116282562562566430661291515713667NULL23056973291NULL000005132194397.384615384615462.7450980392157
814096HHHH5504864305166060505684.313725490196174.4186046511628256256256256560683167128713667NULL25565943291NULL60.206410709002639.77529503067860.0182942603187489717.6133333333330.00139350811021725132194397.384615384615462.7450980392157
574096HLLH1139690904623331684.313725490196174.41860465116282561616256407691232013313749240767229333989.063750333422210.32275273406240.6134969325153371.92256410256410.5201387036543085132194397.384615384615462.7450980392157
94096LLHH1139083733620302684.313725490196174.41860465116281616256256407691232014303653240767325329190.09033670955389.280043799616750.6296194908294551.873333333333330.5338078291814955132194397.384615384615462.7450980392157
14096LLLL533636362616101384.313725490196174.418604651162816161616423015216358242286229000005132194397.384615384615462.7450980392157
154096LMMH1108383804626362684.313725490196176.7441860465116166464256407691232014033681240767325289078.511274110296120.86389568052160.6248302091822871.887692307692310.5297473512632445133184397.384615384615464.7058823529412
214096LHLH1069690804020302084.313725490196176.74418604651161625616256407691232013133776240767229307381.382415254237318.00847457627120.6091101694915251.936410256410260.5164194915254245133184397.384615384615464.7058823529412
224096LHML907073735323402691.489361702127793.023255813953516256641621278661019862342221276986132056.362083689154643.50982066609740.1280956447480791.201025641025640.832621690862511474074397.589743589743685.1063829787234
234096LHMM11010090905336403391.489361702127776.74418604651161625664644076912320111422941240767986214773.002380142808626.14756885413130.8500510030601841.508205128205130.6630397823869434733144397.589743589743670.2127659574468
244096LHMH1561431431236030433391.489361702127776.7441860465116162566425679767239401119628682797659862161000004733144397.589743589743670.2127659574468
164096LMHL907370735026402691.489361702127793.02325581395351664256162127866101137023422212761370132056.362083689154643.50982066609740.1280956447480791.201025641025640.832621690862511474074397.589743589743685.1063829787234
174096LMHM1039683734626332691.489361702127776.744186046511616642566440769123201152925652407671370179770.058479532163729.35672514619880.5847953216374271.315384615384610.7602339181286554733144397.589743589743670.2127659574468
184096LMHH1561461201035033433091.489361702127776.74418604651161664256256797672394011583251227976513701854000004733144397.589743589743670.2127659574468
194096LHLL765656534016332391.489361702127776.744186046511616256161611543375122993221154122942045.064377682403454.72103004291850.2145922746781120.4779487179487182.092274678111594733144397.589743589743670.2127659574468
204096LHLM807070704623302691.489361702127793.023255813953516256166421278661012293462221276229244070.479491623339129.43385326400920.08665511265164641.775384615384610.563258232235702474074397.589743589743685.1063829787234
24096LLLM604036403620262691.489361702127776.7441860465116161616646617223161241266156986000004733144397.589743589743670.2127659574468
34096LLLH735656605020302391.489361702127746.5116279069767161616256115433751940522115416359288.647581441263611.10562685093780.2467917077986182.077948717948720.4812438302073054720274397.589743589743642.5531914893617
44096LLML564043403316201691.489361702127776.74418604651161616641666172231724732661572218000004733144397.589743589743670.2127659574468
54096LLMM735660564330302391.489361702127776.74418604651161616646411543375172152421154172101266.404199475065633.46456692913390.1312335958005250.7815384615384621.279527559055124733144397.589743589743670.2127659574468
104096LMLL634036362620201691.489361702127776.74418604651161664161666172231724732661572218000004733144397.589743589743670.2127659574468
114096LMLM735653534030301691.489361702127776.74418604651161664166411543375172152421154172101266.404199475065633.46456692913390.1312335958005250.7815384615384621.279527559055124733144397.589743589743670.2127659574468
74096LLHL736056564023332091.489361702127776.744186046511616162561611543375132593221154132542045.064377682403454.72103004291850.2145922746781120.4779487179487182.092274678111594733144397.589743589743670.2127659574468
84096LLHM906673664023302391.489361702127793.023255813953516162566421278661013253462221276325244070.479491623339129.43385326400920.08665511265164641.775384615384610.563258232235702474074397.589743589743685.1063829787234
584096HLML937670765326403091.489361702127793.023255813953525616641621278661019862342221276986132056.362083689154643.50982066609740.1280956447480791.201025641025640.832621690862511474074397.589743589743685.1063829787234
594096HLMM11693103935626432691.489361702127776.74418604651162561664644076912320111582931240767986227277.516206073012621.97202320027290.5117707267144321.503076923076920.6653019447287614733144397.589743589743670.2127659574468
604096HLMH1561431431436036463091.489361702127776.7441860465116256166425679767239401121628692797659862486000004733144397.589743589743670.2127659574468
614096HLHL116100961005333502691.489361702127746.511627906976725616256164076912320140464124076735922458.536585365853639.02439024390242.43902439024390.02102564102564147.56097560975614720274397.589743589743642.5531914893617
624096HLHM1501401401435633432691.489361702127746.51162790697672561625664797672394014044432797653592NULL000004720274397.589743589743642.5531914893617
634096HLHH1561461461463633463391.489361702127746.51162790697672561625625615743247280140473521574203592NULL000004720274397.589743589743642.5531914893617
644096HMLL635656533320363091.489361702127793.023255813953525664161621278661012182342221276218132056.362083689154643.50982066609740.1280956447480791.201025641025640.832621690862511474074397.589743589743685.1063829787234
654096HMLM11610086734030332391.489361702127776.7441860465116256641664407691232013763648240767218287678.837719298245620.75109649122810.4111842105263161.870769230769230.5345394736842114733144397.589743589743670.2127659574468
664096HMLH1561161061134336402391.489361702127776.744186046511625664162567976723940144235812797652183089000004733144397.589743589743670.2127659574468
674096HMML1131031001035333403391.489361702127776.744186046511625664641640769123201130527192407671012185568.223611621919831.51894078705410.2574475910261121.394358974358970.7171754321441714733144397.589743589743670.2127659574468
684096HMMM1531231061435336432691.489361702127776.7441860465116256646464797672394011445257927976510121964000004733144397.589743589743670.2127659574468
694096HMMH2361901631464340464091.489361702127776.7441860465116256646425615743247280115042518215742010122231000004733144397.589743589743670.2127659574468
734096HHLL1139390835036633691.489361702127776.74418604651162562561616407691232016923079240767420213169.210782721662930.56187073725240.2273465410847681.578974358974360.6333225073075674733144397.589743589743670.2127659574468
744096HHLM1209690934036433391.489361702127776.744186046511625625616647976723940185229182797654202300000004733144397.589743589743670.2127659574468
754096HHLH2362202102105346533091.489361702127776.744186046511625625616256157432472801909286221574194202512000004733144397.589743589743670.2127659574468
764096HHML1701461461435030333391.489361702127793.02325581395352562566416797672394013433338279765244022964.689265536723230.79096045197744.519774011299440.1815384615384625.50847457627119474074397.589743589743685.1063829787234
774096HHMM2362202202005636363691.489361702127793.0232558139535256256646415743247280134483232157410244022457.881136950904425.581395348837216.53746770025840.1984615384615385.03875968992248474074397.589743589743685.1063829787234
784096HHMH3603533363536040503391.489361702127793.023255813953525625664256306611915157134563142306171244025600000474074397.589743589743685.1063829787234
134096LMML666056504326302391.489361702127776.74418604651161664641611543375132593221154132542045.064377682403454.72103004291850.2145922746781120.4779487179487182.092274678111594733144397.589743589743670.2127659574468
144096LMMM867366664330332391.489361702127793.02325581395351664646421278661013253462221276325244070.479491623339129.43385326400920.08665511265164641.775384615384610.563258232235702474074397.589743589743685.1063829787234
554096HLLL765650604326302691.489361702127776.744186046511625616161611543375122993221154122942045.064377682403454.72103004291850.2145922746781120.4779487179487182.092274678111594733144397.589743589743670.2127659574468
564096HLLM907366634326301691.489361702127793.023255813953525616166421278661012293462221276229244070.479491623339129.43385326400920.08665511265164641.775384615384610.563258232235702474074397.589743589743685.1063829787234
344096MLHL907076705333332391.489361702127793.02325581395356416256162127866101137023422212761370132056.362083689154643.50982066609740.1280956447480791.201025641025640.832621690862511474074397.589743589743685.1063829787234
354096MLHM10610393834333403391.489361702127776.744186046511664162566440769123201154825472407671370193676.01099332548123.40007852375340.5889281507656071.306153846153850.7656065959952894733144397.589743589743670.2127659574468
364096MLHH1531431431405636363091.489361702127776.74418604651166416256256797672394011597248027976513702049000004733144397.589743589743670.2127659574468
374096MMLL705653464023302691.489361702127776.74418604651166464161611543375122993221154122942045.064377682403454.72103004291850.2145922746781120.4779487179487182.092274678111594733144397.589743589743670.2127659574468
384096MMLM866360563020332091.489361702127793.02325581395356464166421278661012293462221276229244070.479491623339129.43385326400920.08665511265164641.775384615384610.563258232235702474074397.589743589743685.1063829787234
284096MLLL564040362620201391.489361702127776.74418604651166416161666172231724732661572218000004733144397.589743589743670.2127659574468
294096MLLM766056564316302091.489361702127776.74418604651166416166411543375172152421154172101266.404199475065633.46456692913390.1312335958005250.7815384615384621.279527559055124733144397.589743589743670.2127659574468
404096MMML867683636030403091.489361702127793.02325581395356464641621278661019862342221276986132056.362083689154643.50982066609740.1280956447480791.201025641025640.832621690862511474074397.589743589743685.1063829787234
414096MMMM1168376704630403391.489361702127776.7441860465116646464644076912320111752912240767986238882.005494505494517.47939560439560.515109890109891.493333333333330.6696428571428574733144397.589743589743670.2127659574468
424096MMMH1631431431335036433391.489361702127776.744186046511664646425679767239401121428692797659862454000004733144397.589743589743670.2127659574468
314096MLML735660504323332091.489361702127776.74418604651166416641611543375132593221154132542045.064377682403454.72103004291850.2145922746781120.4779487179487182.092274678111594733144397.589743589743670.2127659574468
324096MLMM866373634016332091.489361702127793.02325581395356416646421278661013253462221276325244070.479491623339129.43385326400920.08665511265164641.775384615384610.563258232235702474074397.589743589743685.1063829787234
464096MHLL937670634033333691.489361702127793.023255813953564256161621278661012182342221276218132056.362083689154643.50982066609740.1280956447480791.201025641025640.832621690862511474074397.589743589743685.1063829787234
474096MHLM11096901004620363391.489361702127776.7441860465116642561664407691232013833640240767218292780.412087912087919.17582417582420.4120879120879121.866666666666670.5357142857142864733144397.589743589743670.2127659574468
484096MHLH1631331401205033403391.489361702127776.744186046511664256162567976723940144235812797652183089000004733144397.589743589743670.2127659574468
494096MHML11686931005030362691.489361702127776.744186046511664256641640769123201130527192407671012185568.223611621919831.51894078705410.2574475910261121.394358974358970.7171754321441714733144397.589743589743670.2127659574468
504096MHMM1561201331164340434091.489361702127776.7441860465116642566464797672394011436258827976510121894000004733144397.589743589743670.2127659574468
514096MHMH2332231802206330432691.489361702127776.744186046511664256642561574324728011494253021574201012208482.371541501976316.56126482213441.067193675889331.29743589743590.7707509881422924733144397.589743589743670.2127659574468
This post doesn't even scratch the surface of Spatial Index Tuning. For example, if you're using SQL 2012, you could set the index to Auto Grid, which gives you 8 Cell Levels and supposedly is a good marriage for ArcGIS. You also want to look at other performance factors such as Internal Filter Efficiency. There's a lot of Witch Magic and Snake Oil Medicine to Spatial Index Tuning. Hope this blog post gets you started in the right direction!
2 Comments
DougGreen
Very nice hacking. I am ecstatic that someone took the initial step of imperial testing to the next step of gauging it against the helper procs. I originally tested from 16 cells per object down to 1 cell per object and the performance increased as you went down from 16 so I never even considered using more cells per object; especially that high of a number. Way-to-go experimenting and acting on a hypothesis. I may now incorporate yours into mine a bit. However, with everything now on a version of SQL that has the AUTO_GRID option, it's not as big of an issue for us.
by Anonymous User
Not applicable
I will have to review this and some of David Coley's posts when we go to 10.5 / MS SQL Server 2016/7.  Apparently 2017 self optimizes queries although this is different than the spatial aspect you discuss. Nevertheless I am commenting mostly because there is no way to message you. Thomas, you researched stream modeling, yes? I wish I'd published my thesis. I added a dozen or so physio vars to the areas, and tested using D-Infinity and finer spatial res on top of the logistic regression. It didn't improve much on the accuracy surprisingly. I read your papers...a lot! I just wanted to share. If you follow me I believe then we could message.
About the Author
This is a personal account and does not reflect the view or policies of my org.
