Zonal statistic as table always error with 'The input path contains spaces'
11215
23
12-11-2024 08:11 PM
ShuwenLiu
Zonal statistic as table always error with 'The input path contains spaces'. However, the 'Zonal statistic' using the exact setting could successful be run.
This the detail of 'Zonal Statistics as Table'
Tool Path
Input Raster or Feature Zone Data E:\research EMIT\EMIT ArcGIS\EMIT ArcGIS.gdb\EMIT_tiles
Zone Field OBJECTID
Input Value Raster ai_v3_yr.tif
Output Table E:\research EMIT\EMIT ArcGIS\EMIT ArcGIS.gdb\ZonalSt_EMIT_ti1
Ignore NoData in Calculations DATA
Statistics Type MEAN
Process as Multidimensional CURRENT_SLICE
Percentile Values 90
Percentile Interpolation Type AUTO_DETECT
Calculate Circular Statistics ARITHMETIC
Circular Wrap Value 360
Output Join Layer
Messages
Start Time: Wednesday, December 11, 2024 9:52:31 PM
ERROR 000622: Failed to execute (ZonalStatisticsAsTable). Parameters are not valid.
ERROR 010819: The input path contains spaces.
Failed at Wednesday, December 11, 2024 9:52:31 PM (Elapsed Time: 0.20 seconds)
This the detail of 'Zonal Statistics as'
Zonal Statistics
Tool Path
Zone Field OBJECTID
Output Raster E:\research EMIT\EMIT ArcGIS\EMIT ArcGIS.gdb\ZonalSt_EMIT1
Percentile Value 90
Messages
Start Time: Wednesday, December 11, 2024 9:50:48 PM
Value raster being used as snap raster; this is new default behavior.
WARNING 010566: Some zones may not have been rasterized.
Succeeded at Wednesday, December 11, 2024 9:52:31 PM (Elapsed Time: 1 minutes 42 seconds)
Tags (1)
DFarming
Well, apparently I have a space in my Percentile Values filepath, so I guess I can't use this tool now..
JoabelBarbieri
It would be funny if not upsetting !
ISGGISAdmin
Having the exact same error^ this definitely needs to be registered as a Bug.
JeffreyToony_MPD
A couple of my crime analysts are having the same issue but the rest of them are not, when accessing the exact same path. Why does it work for some but not others on the same data path?
JosephRigley
It seems having a dash in the file path can trigger the same or a similar error. Had Viewshed throw this error until the dash was changed to underscore.
JoabelBarbieri
dash or no dash, it doesn't work here
The most infuriating thing is the Esri error./solution to this problem
Description
The Esri Grid format raster does not support path names that include spaces.
Solution
Remove the spaces in the folder names.
Are you kidding me? There's no space to being with.....
And IT WORKS in ARCMAP - it's clearly a PRO issue!
JosephRigley
Indeed, it's not a good look for Pro
Guilherme_Oliveira
This is really annoying and should be marked as bug for sure !
I've got the same error working in ArcgisPro interface. But it seems that it is not related to the path with spaces. Running the same process with the same inputs in a arcpy standalone script, it worked this way:
    arcpy.sa.ZonalStatisticsAsTable(
        in_zone_data=properties,  # feature class in a gdb
        zone_field=id_field, # string
        in_value_raster=fiscal_modules, # raster in a gdb
        out_table=os.path.join(output_gdb, 'zonal_table_mod_fiscal'),
        ignore_nodata="DATA",
        statistics_type="MAJORITY",
        process_as_multidimensional="CURRENT_SLICE",
        circular_calculation="ARITHMETIC",
        circular_wrap_value=360,
Note: my inputs are placed in a path with spaces.
However, if I left the '
percentile_interpolation_type' and 'percentile_values' arguments, the function fails.
Another issue is that the
out_join_layer is not being created as an output.
We are paying a lot for this, ESRI. This shouldn't happen in such a basic tool in a professional software.
DFarming
Good to see this still isn't fixed as of 3.5..
Tools I've seen it in:
Zonal Statistics
Expand
Shrink
All on input fields that have nothing to do with a filepath
NishaniMoragoda
Hi @ShuwenLiu, thank you for sharing this on the community.
I am Nishani Moragoda from Esri. We tried to reproduce this issue based on your test case, using data located in (i) a local drive, (ii) a UNC path, and (iii) a mapped drive (with 8dot3name enabled and disabled in the local drive and mapped drive). But we could not reproduce this error, and our tests worked as expected in ArcGIS Pro 3.5.
If you have steps to reproduce this issue, please contact Esri Technical Support to report this, so we can investigate it using those information. Please make sure to include details on the nature of the data, full data and output paths, drive type, available storage on the drive, and any other information that might help us reproduce and fix this issue.
Thank you for your support to improve the software!
Best regards,
Nishani
