Zonal statistic as table always error with 'The input path contains spaces'
11137
23
12-11-2024 08:11 PM
ShuwenLiu
Zonal statistic as table always error with 'The input path contains spaces'. However, the 'Zonal statistic' using the exact setting could successful be run.
This the detail of 'Zonal Statistics as Table'
Tool Path
Input Raster or Feature Zone Data E:\research EMIT\EMIT ArcGIS\EMIT ArcGIS.gdb\EMIT_tiles
Zone Field OBJECTID
Input Value Raster ai_v3_yr.tif
Output Table E:\research EMIT\EMIT ArcGIS\EMIT ArcGIS.gdb\ZonalSt_EMIT_ti1
Ignore NoData in Calculations DATA
Statistics Type MEAN
Process as Multidimensional CURRENT_SLICE
Percentile Values 90
Percentile Interpolation Type AUTO_DETECT
Calculate Circular Statistics ARITHMETIC
Circular Wrap Value 360
Output Join Layer
Messages
Start Time: Wednesday, December 11, 2024 9:52:31 PM
ERROR 000622: Failed to execute (ZonalStatisticsAsTable). Parameters are not valid.
ERROR 010819: The input path contains spaces.
Failed at Wednesday, December 11, 2024 9:52:31 PM (Elapsed Time: 0.20 seconds)
This the detail of 'Zonal Statistics as'
Zonal Statistics
Tool Path
Zone Field OBJECTID
Output Raster E:\research EMIT\EMIT ArcGIS\EMIT ArcGIS.gdb\ZonalSt_EMIT1
Percentile Value 90
Messages
Start Time: Wednesday, December 11, 2024 9:50:48 PM
Value raster being used as snap raster; this is new default behavior.
WARNING 010566: Some zones may not have been rasterized.
Succeeded at Wednesday, December 11, 2024 9:52:31 PM (Elapsed Time: 1 minutes 42 seconds)
Tags (1)
DanPatterson
MVP Esteemed Contributor
try copying the gdb to a simpler folder name without spaces and report if an error occurs
You could also try specifying a folder as the destination and a *.dbf as the output type, since the output can either be a gdb table or a *.dbf file in a folder
... sort of retired...
Jordenjames
The "Zonal Statistics as Table" tool in ArcGIS can sometimes throw an error if the file path contains spaces. To resolve this, try the following:
  1. Move the input files: Place your input data (both raster and shapefile) in a directory with no spaces in the file path.
  2. Rename files or folders: If the folder or file names contain spaces, rename them to remove spaces (e.g., "My Folder" to "MyFolder").
  3. Use short paths: Use short file paths (e.g., C:\Data\ instead of C:\My Data).
This should prevent the error from occurring.
DFarming
This is not the solution. It will fix the message sometimes, depending on what field is causing the problem. But it also happens on fields that do not take directories, instead integers.
It likely has nothing to do with the filepath, I've been running various Arc projects with a space in the filepath for the past 4-5 years.
Try and manually browse to the file to add it as an input. In random situations (like the one that got me to this thread) I have this error pop up if I'm dragging a layer from the project contents to an input field (or selecting in dropdown), if I instead use the browse button and select the layer in a .gdb it will work fine.
JoabelBarbieri
Who marked this as a solution? It's not, it's misleading and ESRI thinks it's fixed!! Please unmark it as a solution !!!!!!~!
ArmandoFreites16
OK you need select the elements from the folder icon in the window of the geoprocess and the problem solve. I do this
JoabelBarbieri
Wrong. It's not solved. I do this, select using the folder icon and the error persist. This is not the solution to this problem
JoabelBarbieri
It's not fixed It's so frustrating.
 The path is this: C:\Users\user1\Desktop\Stands.shp
Where is the *** space Esri? Where?
Manually browsing doesn't help either. We pay a ton of money for this software and this is what we get
BTW, it works perfectly in ArcMAP, but in the one that is supposed to be the future of GIS, nope! Shame Esri, shame!!
OlympiaTaken
Hey buddy,
Totally understand your frustration, I encountered the same issue and the ESRI troubleshooting is ridiculous.
The workaround I found was to create a new APRX and import only the layers needed for the processing, it solved the spaces problem.
Hope it helps.
ErickFox
This was my fix as well.
