XML import format
7406
01-08-2015 05:34 AM
DanielErklauer
I am attempting to import an XML using the XML tool.  It imports the document  into excel without an issue but ESRI does not like it for some reason, I get the "ERROR 001162".  Can't seem to find much information on this topic or Error other than "The XML file is not correctly
formatted or is not a valid XML document type." I have tried several different version of acceptable XML indentation styles. Below is an example of what I am working with
<?xml version="1.0" encoding="UTF-8"?> <position-report-mail>     <time-offset>         <name>Time conversion</name>         <value>0</value>     </time-offset>     <trace-application>         <name>Trace application</name>         <value>System</value>     </trace-application>     <trace-identifier>         <name>Trace identifier</name>         <value>ats</value>     </trace-identifier>     <trace-address>         <name>Trace address</name>         <value/>     </trace-address>     <package-code>         <name>Sales package name</name>         <value>FLEET_PLUS</value>     </package-code>     <vessel>         <asset-type>             <name>Asset type</name>             <value>vessel</value>         </asset-type>         <vessel-code>             <name>Vessel code</name>             <value>PSF00032</value>         </vessel-code>         <vessel-name>             <name>Vessel name</name>             <value>Apollo</value>         </vessel-name>         <i-m-o-number>             <name>IMO number</name>             <value>6666666</value>         </i-m-o-number>         <call-sign>             <name>Call sign</name>             <value/>         </call-sign>         <flag-code>             <name>Flag</name>             <value/>         </flag-code>         <m-m-s-i>             <name>MMSI</name>             <value/>         </m-m-s-i>         <asset-parameter>             <name>Flag State</name>             <value>USA</value>         </asset-parameter>         <asset-parameter>             <name>Fuel IFO RBO</name>             <value>500000</value>         </asset-parameter>         <asset-parameter>             <name>Tracking</name>             <value>Every 240 minutes</value>         </asset-parameter>         <asset-parameter>             <name>Vessel Type</name>             <value>Bulk Carrier</value>         </asset-parameter>     </vessel>     <position-report>         <trail-date-time>             <name>Position date &amp; time</name>             <date-of-value>2014-09-08</date-of-value>             <time-of-value>17:09:09</time-of-value>         </trail-date-time>         <latitude>             <name>Latitude</name>             <degrees-of-value>41.0</degrees-of-value>             <minutes-of-value>35.0</minutes-of-value>             <seconds-of-value>16.8</seconds-of-value>             <hemisphere-of-value>north</hemisphere-of-value>         </latitude>         <longitude>             <name>Longitude</name>             <degrees-of-value>55.0</degrees-of-value>             <minutes-of-value>59.0</minutes-of-value>             <seconds-of-value>4.8</seconds-of-value>             <hemisphere-of-value>west</hemisphere-of-value>         </longitude>         <speed>             <name>Speed</name>             <value-of-value>21.48148148148148</value-of-value>             <units-of-value>KPH</units-of-value>         </speed>         <heading>             <name>Heading</name>             <value-of-value>241.0</value-of-value>             <units-of-value>DEGREES</units-of-value>         </heading>     </position-report> </position-report-mail>
JakeSkinner
Esri Esteemed Contributor
The Import XML Workspace Document tool takes a very specific format of the XML file in order for it to be work successfully.  You can take a look at the format by exporting a table/feature class to an XML using the Export XML Workspace Document tool.
You would need to parse through this XML and insert the records into a table/feature class.  For example, you could use the xml.etree.ElementTree python module to parse the file and the arcpy.da.InsertCursor access module to update a table or feature class.
JakeSkinner
Hi Daniel,
What does the XML represent that you are trying to import?  Is it a feature class, geodatabase table, etc?  When you say that you are using the XML tool, are you referring to the Import XML Workspace Document tool?
DanielErklauer
Jake thanks for getting back to me.  Yes I am referring to Import XML Workspace Document.  The XML is a table with a position in it lines 69-88 above (see below for clip) so I am trying to plot it as a point.
<latitude>
  •             <name>Latitude</name>
  •             <degrees-of-value>41.0</degrees-of-value>
  •             <minutes-of-value>35.0</minutes-of-value>
  •             <seconds-of-value>16.8</seconds-of-value>
  •             <hemisphere-of-value>north</hemisphere-of-value>
  •         </latitude>
  •         <longitude>
  •             <name>Longitude</name>
  •             <degrees-of-value>55.0</degrees-of-value>
  •             <minutes-of-value>59.0</minutes-of-value>
  •             <seconds-of-value>4.8</seconds-of-value>
  •             <hemisphere-of-value>west</hemisphere-of-value>
JakeSkinner
DanielErklauer
That's what I was looking for thanks
