wxpython
4150
5
11-20-2010 12:35 PM
MikeHunter
For those of you who have wxpython installed, try this:  In the Arcmap python window, type "import wx" and press Enter.  What do you get?  What I get is a complete crash of the entire Arcmap application.  I guess we're stuck with Tkinter until esri gets this fixed.  Comments?
thanks
Mike
JasonScheirer
Esri Alum
Which version of wx and Python are you using?
QT with PyQT may be a more viable option, I know that behaves a lot better when embedded in apps with their own event loops.
MikeHunter
Jason, I'm using the Python2.6 that installed with Arcgis 10 and wxPython 2.8.11.0 Unicode.  But this is not new--I got the same result with Arcgis 9.3 (Python 2.5) if I tried to import wx in a toobox script.
thanks
Mike
NadeemQazi
i used the import wx in ARCMap10.1 and it is crashed. any remedy to do it as i want to use the multimedia of wx in my application.
TonyHowze
Has anyone found a solution to this?
RyanForbes1
Tony,
Not sure if you're still looking for a solution since it's been a while since this thread has been touched but it came up in my searches and I would like to offer a solution so that folks in the future can see it too.
I was able to get around this issue by writing a separate script, saving it as a .pyw (thus forcing pythonw.exe to read it, rather than python.exe) and then importing it as a 'library' into my main script.  Since I am at the moment writing a Python Add-in for Arc Catalog I'll use that as an example.
First you write the code that gives you your window/app/etc
#!/usr/bin/python
#wxWorkAround.pyw
import wx
# This just gives up a blank, re-sizable window.
def main():
 app = wx.App()
 frame = wx.Frame(None, -1, 'simple.py')
 frame.Show()
 app.MainLoop()
(Lets say you were trying to have a window pop up when you clicked a button in a Python Add In) Save that script as a .pyw and then import it like you would any other script, and then call it like this:
class sampleButton(object):
    """Implementation for GRRTool_addin.sampleButton (Button)"""
    def __init__(self):
        self.enabled = True
        self.checked = False
    def onClick(self):
        wxWorkAround.main()
It has worked for me (at least within ArcCatalog), so I hope this helps somebody in the future.
