working with string variables in a FeaturClass
2414
08-12-2010 08:08 PM
Jose_LuisGarcinuno-Oporto
I am trying to create a variable to be used in the select statement. So far, this is the code that I have right now.
rows1 = gp.SearchCursor(a + "copySelect1")
        row1 = rows1.Next()
        while row1 <> None:
           road = row1.Getvalue("ROADNAME")
           print road
           # Process: Select...the next line of code works, so the challenge is How to incorporate road variable here, to replace 'RD-300', it is in square brakets because it is a FeaturClass in a GeoDataset, I know how to works with shapefiles but this is not the case.
           gp.Select_analysis(a + "copySelect1", "Rclip" + a + "Select", "[ROADNAME] = 'RD-300'")
           gp.Select_analysis(a + "copySelect1", "Rclip" + a + "Select", "'[ROADNAME] = + str(road)), my problems are the double quotes, road variable is a string variable, what happen if it is integer?
Thanks in advance
ChrisMathers
You dont want to make the change directly in the tool inputs. Make the string before and just drop it in as a variable.
query="[ROADNAME] = '"+road+"'"
gp.Select_analysis(a + "copySelect1", "Rclip" + a + "Select", query)
Thanks a lot Chris, its work perfectly, I really appreciate your time.
