Will UNION solve the following question?
600
02-21-2019 09:20 AM
JerryGriffith1
Will the UNION function get at the following problem?
I have a polygon layer that consists of areas in  a floodplain that are also in an "undeveloped" land use category.
Now I am also using the information from a land ownership parcels (PARCELS) file, and I want to know which of these undeveloped floodplain polygons are in land parcels that are greater than 40 acres (or any other size).
Will a simple UNION function allow me to get this?
DanPatterson_Retired
Union—Help | ArcGIS Desktop
retains the attributes of both files.  You then have to query for those features that contain both conditions in the table.
A subset query for those meeting the first condition on the shape_area field will give you the undeveloped parcel on the flood plain that are greater than your specified area.
Of course... shape_area will be in the units of your data set, which should be in a projected coordinate system.  If they are decimal degrees, then you have a few hoops to go through to but
Calculate Geometry Attributes—Data Management toolbox | ArcGIS Desktop
has an option to calculate the geometry of your features in acres
