ArcGIS Pro 3.0.2
I've read somewhere that Copy gp-tool fails to copy a dataset to a drive root by design. And yet, Create Feature Class successfully creates a shapefile in
I use ArcGIS Pro SDK, so I noticed that GetDefinition method throws an exception internally failing to create a Uri while initializing a FileDatastore. So I suppose that the root scenario is not tested well.
My question is: Why is the root path forbidden although I can successfully create a dataset there?
