Want to dissolve adjacent polygons but no common edges.
9257
16
05-08-2013 11:52 AM
HaoLiu1
I have a bunch of parcel data, I want to join the polygons basing on the same owner name.
Even they are not touched, I want merge them together, such a 100 feet tolerance. The purpose is to show the somebody's properties without too much separated lines.
Like this
[ATTACH=CONFIG]24136[/ATTACH]
I have some programming experience, but just start to try to get the tool by python script, and tried arcgis add_in wizard.
If there is some idea about the script work flow, it will be really helpful!
HaoLiu1
Here are pictures showing a sample input and output of the model.  My model used 100 feet as the aggregation distance.
Sorry that I am not very familiar with the iterator tool.
Is the iterator type the "Feature Classes", cause I cannot assign the owner name field and the output is odd default?
[ATTACH=CONFIG]24210[/ATTACH]
Or it is "Field Value" iterator, but the output is odd default and cannot be the input of Aggregate tool, what's more, I cannot get the built in %Value% variable outputs (the light green-blue oval)?
[ATTACH=CONFIG]24211[/ATTACH]
I really appreciate your help. I am still not totally understand it~
HaoLiu1
Oh, I got it, it is a loop of selection, feature selection.
RichardFairhurst
Sorry.  I forgot there are several iterator choices.  Yes, it is a feature selection iterator that would iterate selections based on your owner name values.
curtvprice
Desktop 10.1 Help: Iterate Feature Selection
ModelBuilder @ 10.x has become a very useful tool for personal workflows like this!
HaoLiu1
Thank you very much, it is really helpful.
TobyAlker-Jones
Hi there,
I am hoping to perform a similar task, though without the use of the 'Aggregate Polygon' tool (no ArcInfo!). I need to iterate through a polygon feature class and append all contiguous polygons and then see if there size is greater than 200 ha.
Any tips on how to achieve through python in ArcGis 9.3.1?
Cheers
Toby
curtvprice
Have you considered using Dissolve (Data Management) followed by Select Layer By Attributes? Both of these tools are supported with a Basic license.
