Viewshed Output Data
899
09-06-2013 02:48 PM
RachelAlbritton
I'm working on a viewshed analysis for multiple points, and comparing viewshed change from one time period to another. Is it possible to get a viewshed output that provides the viewshed in degrees? For example, if I input the parameters to scan 180 degees, how many degrees of that 180 are actually viewable? I know you can input the azimuth for the analysis to consider, but I'm not sure if you can get these results in an output as well.
