Using Weighted Sum in Model Builder
2067
04-10-2011 10:02 AM
DaniellePelletier
I'm making a model where the end result is a weighted sum of 4 reclassified rasters.  I want the user to easily be able to change the weighting of each of the rasters being used, without having to go into the model itself.  Is there a way to set the raster weights as parameters for the model?
I guess in short I'm wondering how to make the Weight within the weight sum a parameter, the parameters option is completely greyed out when I right click the icon, so it's not working in the usual way I would create a parameter.
Thank you in advance!
PaulBooks_CoA
I have this same question. Were you able to find a workaround for this?
