Using Feature Iterator and getting 'All the Inputs Are Not Current'
2833
05-14-2012 09:23 AM
KurtMenke
I'm putting together a model that will iterate features in a shapefile. With each selection (a development site) it will run an Extract by Mask against a raster, convert the result to a polygon, add a couple of fields and run some Summary Statistics. It is pretty straightforward. The model successfully runs the Extract by Mask. Then for all other operations it says, "All the inputs are not current" and produces no output. Any ideas on what might be going on would be greatly appreciated. I'm running ArcInfo ArcGIS 10 SP3 on Windows 7 64 bit. An image of the model is attached below.
Thanks!
Kurt
[ATTACH=CONFIG]14310[/ATTACH]
