Using a variable (in SQL) to select by attribute with Python
7042
8
12-02-2010 07:14 AM
MichelleConvey
Hi there,
I am trying to select out any polygons from a feature class that are greater than the standard deviation of the entire feature class.  I firstly calculate the standard deviation, store that in a variable and then am getting stuck on how I need to incorporate that into my sql query.
It keeps giving me error 000358 when it gets to the SelectByAttribute part and no matter what I change it doesn't appear to make a difference.  I am pretty new to this so sorry if it's massively inefficient.
I have posted the code below and any help would be greatly appreciated!
import sys, arcgisscripting
gp=arcgisscripting.create()
gp.OverWriteOutput = True
# Variables
table = "C:\\temp_Statistics"
field="STD_AREA"
# Process
rows=gp.searchcursor(table,"","",field)
row=rows.next()
while row:
    queryValue = row.STD_AREA
    print queryValue # check that the number is stored in this variable
    row=rows.next()
# Make feature layer
in_features = "C:\\tester.shp"
out_layer = "temp_layer"
gp.MakeFeatureLayer_management (in_features, out_layer, "#", "#", "#")
print "made feature layer"
# Select by attribute based upon the value obatained from standard deviation calc.
where_clause = "area" >= queryValue
out_feature_class = "C:\\test_Copy.shp"
gp.SelectLayerByAttribute_management(out_layer, "NEW_SELECTION", where_clause)
print "selected features"
# Copy the selected features to a new layer
gp.CopyFeatures ("temp_layer", out_feature_class, "#", "#", "#")
print "features copied"
Thanks!!
AndrewChapkowski
Try changing this:
to
where_clause = "\"area\" >= " + queryValue
MichelleConvey
Thanks Andrew!
That did the trick - all I had to do after that was to change my variable to a string:
where_clause = "\"area\" >= " + str(queryValue)
Cheers,
Michelle
RoryHall
Hi Michelle,
Just an additional thought. I have had similar problems in getting the syntax right, so have in some circumstances I have created what I need to to in a basic model using modelbuilder, then exporting that as a python script. Opening the script generally gives you the syntax you are looking for.
cheers ~ Rory
DanielAbera
Hi how about passing morethan one variable. Iam getting an error message
part of the code :-
MER  = sys.argv[1]
TWP  = sys.argv[2]
RNG  = sys.argv[3]
SEC  = sys.argv[4]
Expression ="MER= "+MER "AND" "TWP= "+TWP "AND" "RNG= "+RNG "AND" "SEC= "+SEC
# Process: Select Layer By Attribute
arcpy.SelectLayerByAttribute_management(lyr, "NEW_SELECTION", Expression)
any idea,
Thanks
FabianBlau
Expression = '"MER"= ' + MER + ' AND "TWP" = ' + TWP + ' AND "RNG" = ' + RNG + ' AND "SEC"= ' + SEC
BruceNielsen
If any of your variables are strings instead of integers, they need to be surrounded by single quotes in the expression, which makes things a bit more complicated. I like to use string substitution:
Expression = "\"MER\"= '%s' AND \"TWP\" = '%s' AND \"RNG\" = '%s' AND \"SEC\"= '%s'" % (MER, TWP, RNG, SEC)
MathewCoyle
Honored Contributor
Or even better. Through this method you don't have to worry about what format the variables go through as. Add field/attribute delimiters as needed.
Expression = "MER = {0} AND TWP = {1} AND RNG = {2} AND SEC = {3}".format(MER,TWP,RNG,SEC)
I should also add this was only implemented in Python 2.6, so ArcGIS 10 and above.
DanielAbera
Thanks guys !!!
