Use Con with two rasters
3358
6
06-30-2021 06:35 AM
mody_buchbinder
Hello all
I am trying to write a python program that will create a new raster by condition of two rasters.
I can do it with the con function like this:
res = arcpy.sa.Con((Raster1 == 0 & Raster2 == 0),1,0)
For the con function you need to create a Raster() before you can use it and then save the results.
From the other hand arcpy.gp.con_sa  can get a path of tif as parameter and the final result name is parameter.
I could not find the way to put two rasters in the condition (it is usually "value == 0" of the raster in the new parameter.
Any ideas?
JayantaPoddar
Not sure if I am able to understand the concern.
Are you looking for an expression like?
arcpy.sa.Con(((Raster1 == 0) & (Raster2 == 0)), 1, 0)
Think Location
DavidPike
MVP Notable Contributor
What do you mean by python program? If you mean as a python script tool, can't the output filename when using .save() just be used as a parameter?  If you mean as a GP tool/task, then the result object of .save() would just be put as arcpy.SetParameter(x) and the output set as derived (a while since I've done that so may not be exactly correct).
DanPatterson
MVP Esteemed Contributor
Did you try something like this... pick one or the other to see if it works... they lead to the same code in any event
r0 = "c:/path/some.tif"
r1 = "c:/path/another.tif"
arcpy.gp.con_sa((Raster(r0) == 0) & (Raster(r1) == 0), 1, 0)
# ---- or!!
arcpy.sa.Con((Raster(r0) == 0) & (Raster(r1) == 0), 1, 0)
... sort of retired...
mody_buchbinder
Hi Dan
Please read my previous question here: https://community.esri.com/t5/python-questions/what-is-the-way-to-call-spatial-analysis-tools-in-arc...
The arcpy.sa.con_sa have different parameters and the first parameter is the input raster so you cannot gives two rasters.
I will look into the numpy
Thanks
DanPatterson
Mody, if you want to bring the raster back in, check the optional parameters for rastertonumpyarray and numpyarraytoraster
RasterToNumPyArray—ArcGIS Pro | Documentation
RasterToNumPyArray (in_raster, {lower_left_corner}, {ncols}, {nrows}, {nodata_to_value})
NumPyArrayToRaster—ArcGIS Pro | Documentation
NumPyArrayToRaster (in_array, {lower_left_corner}, {x_cell_size}, {y_cell_size}, {value_to_nodata}, {mdinfo})
This allows you to maintain the spatial location and nodata values.
the lower left corner has examples in the help eg
lowerLeft = arcpy.Point(in_raster.extent.XMin, in_raster.extent.YMin)
DanPatterson
or a numpy lesson... verbose, showing that arcpy plays nice with numpy
a1 = arcpy.RasterToNumPyArray("c:/temp/a0.tif")
b1 = arcpy.RasterToNumPyArray("c:/temp/b0.tif")
whr = np.logical_and((a1==0), (b1==0))
out = np.where(whr, 1, 0)
a1
array([[1, 0, 3, 0],
       [3, 2, 1, 1],
       [4, 3, 0, 3],
       [2, 0, 0, 1],
       [2, 4, 2, 1]])
b1
array([[1, 1, 2, 4],
       [3, 1, 0, 3],
       [4, 2, 0, 1],
       [3, 4, 1, 2],
       [1, 0, 2, 0]])
whr
array([[False, False, False, False],
       [False, False,  True, False],
       [False, False, False, False]])
out
array([[0, 0, 0, 0],
       [0, 0, 0, 0],
       [0, 0, 1, 0],
       [0, 0, 0, 0],
       [0, 0, 0, 0]])
my favorite raster goto 😉
