Use Calcuate Field to replace values
1170
09-19-2019 08:17 AM
JohnBrand
I'm trying to use the Field Calculator (python) to replace existing values (string) in Field1 with the values in Field2 (string) but only if Field2 is not Null.
Having trouble with the syntax.
John
LanceCole
John,
In Field Calculator you will want to create a def statement in the code block and pass the values of Field1 and Field2 to this statement.  The Statement will look something like the following:
def checkValue(f1, f2):
  if f2 is None:
    return f1
  else:
    return f2
You would call the function using:
checkValue(!field1!, !field2!)
LanceCole
John,
  if f2 is None:
    return f1
  else:
    return f2
