Trying to publish a ECW Raster into Enterprise portal as a tile cache
2060
03-05-2022 05:11 PM
DamiBarnes
I am sorry if this all sounds very Noobish, I am very much learning all this and the lingo on the fly.
We are a small council that has just upgraded an old on premise ArcGIS enterprise setup to an Azure hosted one so are in the process of migrating data across and also learning how to use portal for the first time.
I have been able to migrate our point/Polygon/polyline layer across while projecting it into an updated coordinate system, But i have been struggling trying to work out a workable process for what to do with our raster image.
It is a 7GB ECW file, roughly triangluar shaped area of our council. the ECW is in a Projected Coordinate system for our region.
There are 4 bands and if i set the symbology of the Alpha band to all Opacity, then it overlays nicely on the Esri standard topographic map and hillshade.
We have asked ESRI what to do in order to make this available in the new environment and they have suggested making it a tile package for use in Portal.
So the best i can work out is i am supposed to use the following Geoprocessing tools:
Generate Tile Cache Tiling scheme.
Source=the ECW
Output scheme = the name of the XML i am going to create
generation method = predefined
Predefined tiling scheme = the Esri Online/Google/bing tiling scheme
the cell sizes are all then determined, i don't edit anything there,
tile size 256x256
Tile format Mixed (I read that i need it to be mixed to account for the transparency)
Tile compression quality 100
Now i then use Manage Tile Cache
Cache Location: Place on C:\
Cache Name:  A suitable name for the cache that gest created
manage mode: recreate all tiles
Input data source: the ECW
Input tiling scheme: Import scheme
Import Tiling scheme:the xml i created from the generate tile cache tiling scheme step above
Minimum cached schale and maximum cachedd scale then prepopulate
Scales prepopulates.
 I don't define an area of interest
When this finishes, I now can't seem to hide that alpha band (which now generates ad Band 4) and istead it is now a muddy white image around my map but i proceed anyway
Next tool is Export Tile Cache
Input tile cache: the tile cache generated from Manage Tile cache above
Output tile cache Location: a place on c:\
Output Tile Cache Name: the name of the tile cache i am going to create
export cache at TPKX
Area Of interest: I try and get close to my image but  there are still white bits all over
Finally, i then use Share Package
Input package: is the tpkx i created earlier
summary, Tags, credits, and folder are all set
so i now have a TPKX file in Portal as per the recommendation from ESRI
But it has the muddy white outline still so it looks bad when i overlay over the topographic image, and it doesn't zoom in as far as it shows in Gis Pro. I also lost the ability to have a streetmap link work when i set it as a basemap which i assume is because my oringnal raster was not the WGS 1984 coordinate system.
I am wondering if i took the right steps to get to my enpoint here or if i should have done things differently?
i used these two youtube videos along with the ESRI
https://youtu.be/NfSVI0YSZ2I
https://youtu.be/1ZT8hUXQsms
An overview of the Tile Cache toolset—ArcGIS Pro | Documentation
There was a lot of language i didn't understand and did some steps different based on the assumption i was trying to make my image compatible with Gmaps/Esri/Bing as well as using Enterprise Portal instead of GisOnline.
Have i missed something fundamental how i was supposed to deal with the ECW in the first place?
Is there a Raster Tile cache diagram and flow for beginners that i might be able to refer to?
Am I right in that I suspect i have to Project my Raster to WGS1984 as well (which then raises a number of other questions and settings about the project raster tool)
Tags (3)
