Topo to raster error!
5392
04-09-2012 03:15 AM
UrosDjuric
Can someone help me please,
I am trying to use Topo to raster tool on polyline shapefile, but i am always getting this annoying two errors:
ERROR 010235: Returned error from Topo_To_Raster.
ERROR 010067: Error in executing grid expression.
Failed to execute (TopoToRaster).
I cannot find why is that happenig!
Database is in available on download link, CONTOUR height field is called "Visina"
Thanks in advance ...
I am using ArcGIS v 10...
Download
http://www.2shared.com/file/CYVxEDBx/Bgd.html
TarunJaiswal
Greetings!
I see that you are using personal geodatabase for storing your contour file. Are you also storing your output raster in the same geodatabase? If yes, there is a possibility that you might be running out of space (depending upon the cell size of output raster) as a personal geodatabase has a size limit of 2 GB.
I would suggest you to use file geodatabase as also mentioned in the following web help documentation.
Types of geodatabases
Hope this helps.
Thank you.
TarunJaiswal
Greetings!
Hope this helps.
Thank you.
UrosDjuric
Greetings!
Hope this helps.
Thank you.
Oh yes ... I totally forgot on presonal GDB limit in size .... silly me! 😄
When I imported shapefile in file geodatabase, i solved my problem ...
But, initally I have tried to do topo to raster on single shapefile (out of gdb) and I got same error? Any reason why that?
Many many many times thank you!
