tool for joining contours.
1342
11-12-2012 07:00 AM
GualbertoHernández_Juárez
Hi all.
I created several contours from rasters, now need to unite them, know if there is any tool that allows me to do this?
thank you very much
Gualberto
JakeSkinner
Esri Esteemed Contributor
Hi Gualberto,
You can use the Merge tool to accomplish this.
Hi Jake.
I have 120 raster, therefore I generate 120 contours (these are data of a forecast of the 120 hrs specifically
the variable "pressure reduced at sea level").
I need to animate the contours, there is some possibility of mosaic-like? how could animate the 120 contours?
Thank you very much Jake.
Gualberto
JakeSkinner
Can you explalin a little more what you mean by animate?  Merge is essentially the same as mosaic, only it is used for vector data rather than rasters.
