Tool Calculate Field cannot use VB expression for service
4162
09-12-2016 03:05 AM
JustinGleeson1
I have a model working in ArcGIS 10.3 that uses a .py script to run through a series of routines. One of them is Calculate Field and I have use Python_9.3 in the code. However, when I try and publish the service on my server I get an error: "Tool Calculate Field cannot use VB expression for service"
This is the code in the .py script. Any ideas where the problem is? I don't have VB anywhere.
arcpy.CalculateField_management("PopSummary", "PcPop014", '(!Sum_Pop_014T11! / !Sum_Pop_T11! )*100', "PYTHON_9.3")
Thanks
Justin
FC_Basson
Try wrapping your calculate expression in double quotes
JustinGleeson1
HI FC,
I tried that. The model itself ran on ArcGIS but once I tried to publish the service the same error came up.
Code with double quotes below. Perhaps this is not what you meant?
arcpy.CalculateField_management("PopSummary", "PcPop65p", "'(!Sum_Pop_65pT11! / !Sum_Pop_T11! )*100'", "PYTHON_9.3")
Thanks
Justin
FC_Basson
Hi Justin, yes I meant replace the single quotes with double quotes.
JustinGleeson1
FC, that worked out well for me
Thanks
