Toggle a layer on or off using ModelBuilder
954
04-19-2014 08:38 PM
SunilBharuchi
How can I toggle a layer(s) ON or OFF using ModelBuilder commands?
KimOllivier
Honored Contributor
You can control the table of contents in ArcMap using arcpy.mapping module commands. So you would need to create a tool that toggled the layer and then add the tool to ModelBuilder. You need to build the tool with input and output parameters.
