Splitting and Merging Attributes for Closest Facility Output
900
06-18-2012 08:08 AM
StephenCrim
Dear All,
I am working with a dataset that has approximately 24,000 routes produced from the Closest Facility function in Network Analyst. These routes have trip-volume numbers attached in an attribute field that I'll call TRIPS. I want to flatten all of these routes such that all identical sections of the routes are merged/dissolved with a summation of the TRIPS field. I am running an ArcEditor license.
I am trying to find the most efficient solution to creating this layer. My initial workflow was the split the polylines at their vertices, add centroid X coordinate and Y coordinate fields, and then dissolve on those coordinate fields, with a SUM function on TRIPS. However, the splitting part is giving me trouble; I have ET GeoWizards (full version), but its Split Polylines feature produces an output shapefile that seems to crash somehow after a few moments; I get an error message that says something to the effect of "number of table rows does not match geometry" or something similar.
Can anyone suggest a better way to accomplish what I'm doing here?
Many Thanks,
Stephen
