Spatial Join CRASHING at 10
10620
23
07-22-2010 05:58 PM
TedCronin
So, I can run about 5 consecutive processes for a spatial join before Wing crashes and processes no more.  Using a Point and a Poly layer to Join.  Point layer is 774,796 records.  Poly layers vary, but are much smaller than point.  Spatial Join in a list, which makes this a tedious process in that I get to wait for the crash and then remove the layer from the list and then reprocess the list, so it kinda makes using lists not optimal.  Physical Memory drops to about 34,000 K before the crash.  It steadily goes down from the first to the sixth layer, with the sixth layer not completing successfully.
Good Times.
oh, this is running in a File GDB.
There is NO error number generated, it just stops.  Believe it is runaway memory.
NobbirAhmed
Esri Alum
The following Spatial Join patch fixing the issue is now available on resource center through this link:
http://resources.arcgis.com/content/patches-and-service-packs?fa=viewPatch&PID=160&MetaID=1857
ModernElectric
The new Patch does not seem to fix everything though. I am still having problems with the Spatial Join tool before and after I installed the patch. I have not had this problem before (I believe SP3 and/or SP4).
I bring (2) different feature classes into a new .MXD:
     Service_Location feature class (Point)
     Map_Grid feature class (Polygon)
When I open up the Spatial Join dialog box, the only feature class I can select is the Map Grid feature class. It doesn't even give me an option to select Service_Location or drag and drop it either.
I use to use this tool for a number of combination projects and analysis, but right now, do not have the ability to do so.
Is there a work around?
I am trying to make a new feature class that says - find every "Point" that is inside a "Polygon" and combine them together.
Thanks
NobbirAhmed
Esri Alum
Sorry to hear that. To prepare a workaround I need your data and detail steps you are trying - email me at [email protected]
ModernElectric
I was able to create a "Work-Around" to get this to work. Previously - I had both Feature Classes I needed in separate Geodatabases. I had the problem of one of the feature classes not being able to be select to be used in the Spatial Join tool. So....I created a new File
Geodatabase - imported both feature classes I needed - and was able to successfully complete the Spatial Join. Before SP3 or SP4, I
had no problem selecting multiple feature classes from different Geodatabases and still be able to run the tool.
