Last post mentioned this was fixed in 10 SP2, I'm running SP3 and experiencing a similar issue. A model I've created that uses Spatial Join works fine in 9.3.1 but crashes in Arc10. I isolated it down to just the Spatial Join command, and created a model that just executes spatial join and it crashes every time. I tested the background geoprocessing on/off solution with no success. Same process works fine in 10 when executed outside of ModelBuilder. The spatial join is one-to-many, closest with a set maximum search distance. Any advice on solutions would be most appreciated.
Last post mentioned this was fixed in 10 SP2, .......The spatial join is one-to-many, closest with a set maximum search distance.
The problem Nate is experiencing was logged as NIM079126:http://support.esri.com/en/bugs/nimbus/TklNMDc5MTI2However, it looks like maybe it was listed as "declined" and that maybe ESRI was not able to reproduce it....
The following Spatial Join patch fixing the issue is now available on resource center through this link:http://resources.arcgis.com/content/patches-and-service-packs?fa=viewPatch&PID=160&MetaID=1857
