Simple Select Parcels, Buffer and Zoom too Query in ModelBuilder.. v9.3
3367
03-22-2011 06:06 AM
AlexGray
I am trying to create a model where someone has to
  1. Enter the Parcel ID they are looking for
  2. Select all the adjacent parcels
  3. Automatically zoom to the extent of the selected parcels.
I think this is doable within Modelbuilder but its just not working..
Can't find the zoom tool to put into modelbuilder
Any help is greatly appreciated..
Thanks, Alex
BBicking1
Thanks, Alex
Hi Alex,
one [sniffty] way to do it is: use the CalculateValue tool with the attached code. Set a Precondition on CalcValue to the output from SelectByLoc. Btw - in SelectByLoc: for the Relationship parameter I used the "Boundary Touches" option to get all adjacant parcels.
Let me know if it works for you - it does for me.
Barbara Bicking
FrankVignati
Another way is to save this as a python script and add it to your toolbox then put it in your model with the output of the select by location as a precondition
#### Created By:  Frank
#### Created on:  03/22/2011
#### Description: Zooms to a selected elements in a layer of an MXd
## Set the necessary product code
import arcinfo # If you do not have an ArcInfo license change this
## Import arcpy module and environment module
import arcpy
import arcpy.mapping
## Sets the MXD file, if run out of ArcMap set the full path to the MXD file ex: "C:\Workspace\Parcel_Map.mxd"
MXD = arcpy.mapping.MapDocument("CURRENT")
## Set Data Frame for the layer to select from to the data frame the selected element is in
DF = arcpy.mapping.ListDataFrames(MXD, "Layers")[0] #If the data frame name is not Layers change this
## Pan to selected features
DF.zoomToSelectedFeatures()
## Refresh data farame
arcpy.RefreshActiveView
AlexGray
Hi Alex,
Barbara Bicking
Barbara,
Thanks.. this looks like I am heading in the right direction.. only problem I am running into is that arcpy.. isn't that used for ARCGIS 10? I am still using 9.3..
Its probably just a syntax problem I am running into for the zoom to selection script..
Alex
