Select Data from one feature based on a different feature that is selected
831
05-07-2010 05:19 AM
PaulMcBride
Anyone have any suggestion of how to select a point feature by attribute based upon a selected polygon feature.  Both features have identical fields that correspond to each other but I can't get them to talk to one another.
The purpose of the tool is to select a polling location based upon the user's address.  I have the model/script to select the voting precinct, but now need to select the polling location based on that selected voting precinct.
DarshaHardy
Not sure if this is what you're after
Outer loop though feature class to extract an attribute from specified field
Use value to construct 'where' clause
Inner loop selects features(s) in second feature class
Selection syntax is assuming a string field in a shapefile and I'm using ArcGIS 9.2
import arcgisscripting
gp = arcgisscripting.create()
gp.OverwriteOutput = 1
fcPoly = "C:/test_polygons.shp"
fcPoint = "C:/test_points.shp"
myField = "TEST_FIELD"
gp.MakeFeatureLayer(fcPoint,"fcPoint_lyr")
outers = gp.SearchCursor(fcPoly)
outer = outers.Next()
# Print road name and road type
while outer:
    myVal = outer.GetValue(myField)
    strWhere = '"' + myField + '"' + " = '" + myVal + "'"
    gp.SelectLayerbyAttribute_management("fcPoint_lyr", "NEW_SELECTION", strWhere)
    inners = gp.SearchCursor("fcPoint_lyr")
    inner = inners.Next()
    while inner:
        # do stuff here with the selected rows
print "done looping"
