Select by attribute query to select the maximum value entry
3886
11-20-2014 03:02 PM
HemantAngarkar2
I am trying to select by attribute query in a file geodatabase,
[Address_ID] In (SELECT [Address_ID] FROM [Sunset_and_Goldengate_Monday_II] GROUP BY [Address_ID] HAVING Count(*)>1 )
It is not working, whereas it works in Personal geodatabase. I want o select features which has maximum values in let's say b field. And I have Address_ID field which has duplicate entries like this;
Address_IDB
A1
A2
A3
B1
B2
So I want to select A which has 3 (Maximum) as a value in B field, also b which has 2 (maximum) as a value.
Any help is appreciated.
DarrenWiens2
A quick search yielded this Knowledge Base Article (Select minimum and maximum values in the Select By Attributes dialog box) explaining that this cannot be done in File GDBs and these solutions, which are probably more complicated than you want to see, on GIS StackExchange.
HemantAngarkar2
Thanks Darren, I am on 10.2.1 where these queries don't work. It works in 9.3.1. GIS Stackexchange were not working on select by attribute. Thanks for the help.
XanderBakker
Esri Esteemed Contributor
The field names are between square brackets as with a file geodatabase you don't use brackets nor quotes around the field names.
HemantAngarkar2
I tried without brackets and without quotes, still nothing. thanks for the reply!!
