Script tool for Geoprocessing Service
1634
6
08-03-2010 06:29 AM
AdrianHughes
Does anyone have any examples of script tools used in an ArcGIS server geoprocessing service? I guess they have to be written differently to script tools in the desktop environment but can't find any documentation on them
KevinHibma
Aside from watching your input/output parameters (being supported and how you reference them)...the scripts aren't really any different.
Do you have a workflow or script that you're having problems with?
AdrianHughes
I've read about the limitations in inputs and outputs. I had a script that worked fine in the desktop environment but gives a very ambiguous error on the server. The message in server manager is simply Error:Failed. Event viewer does not shed anymore light either.
I still get the error with the very simplified script below. Perhaps its as you say to do with referencing the parameters. Is it correct to use sys.argv[]? My inputs are just two feature sets and a couple of strings
import sys, string, os, arcgisscripting
def InitialSetting():
    try:
        global gp
        gp = arcgisscripting.create(9.3)
        gp.Addtoolbox(r"C:\Program Files\ArcGIS\ArcToolBox\Toolboxes\Data Management Tools.tbx")
    except:
        print "error"
        sys.exit(0)
    else:
        global Printboth
        def Printboth(msg):
            print msg
            gp.addmessage(msg)
        Printboth("Importing ArcGIS scripting object successful")
InitialSetting()
gp.overwriteoutput = 1
# Load required toolboxes...
gp.AddToolbox("C:/Program Files/ArcGIS/ArcToolbox/Toolboxes/Conversion Tools.tbx")
gp.AddToolbox("C:/Program Files/ArcGIS/ArcToolbox/Toolboxes/Data Management Tools.tbx")
# Script parameters
Method = sys.argv[1]
Binomial = sys.argv[2]
Known_Location_Points = sys.argv[3]
Inferred_Species_Range = sys.argv[4]
Hydroshed_Layer =  "Hydrosheds_Taiwan"
AndrewChapkowski
The web help has multiple of published GP service examples: http://webhelp.esri.com/arcgisdesktop/9.3/index.cfm?TopicName=Guide_to_the_geoprocessing_service_exa...
I would also use gp.getparameter() or gp.getparameterastext() to get your inputs instead of sys.argv. You shouldn't have to reference the toolboxes either.
In general when writing scripts I try to follow this format:
import sys
import os
import traceback
import inspect
import arcgisscripting
class ErrorHandling(object):
    def trace(self):
        tb = sys.exc_info()[2]
        tbinfo = traceback.format_tb(tb)[0]
        # script name + line number
        line = tbinfo.split(", ")[1]
        filename = inspect.getfile( inspect.currentframe() )
        # Get Python syntax error
        synerror = traceback.format_exc().splitlines()[-1]
        return line, filename, synerror
if __name__ == '__main__':
    try:
        #!!!!! place python logic here !!!!!
    except arcgisscripting.ExecuteError:
        # Return GEOPROCESSING specific errors #
        EH = ErrorHandling()
        line, filename, err = EH.trace()
        gp.adderror("Geoprocessing error on " + line + " of " + filename + " :")
        for msg in range(0, gp.MessageCount):
            if gp.GetSeverity(msg) == 2:
                gp.AddReturnMessage(msg)
        gp.AddError(gp.GetMessages(2))
    except:
        # Return any PYTHON or system specific errors #
        gp.AddError("Python error on " + line + " of " + filename + " : with error - " + err)
    finally:
        del gp
Hope this helps.
AdrianHughes
Hi
I've seen those examples but none of them use script tools. I'm still getting the same error (Error:Failed) for the very simple code below. Is there any way of getting a more meaningful error message
# Script parameters
Method = gp.GetParameterAsText(0)
Binomial = gp.GetParameterAsText(1)
Known_Location_Points = gp.GetParameter(2)
Inferred_Species_Range = gp.GetParameter(3)
AndrewChapkowski
Did you enable messaging on your service, this will give you the error messages from the server? To do that, you'll need to stop the service and check the show messages check box in catalog.
Do you have your script/toolbox saved in a location where the server can access it?  For example,
I place my scripts and toolboxes in a directory inside the \\computer-name\arcgisserver folder.  Then I publish my script from the UNC referenced name.
Another consideration, is to reference the script by UNC path name.
Attached is a toolbox that contains a script that can be published to server, hopefully this will help.
AdrianHughes
I didn't have messaging enabled. Thanks, thats helped a lot and I've now got a basic script to work.
