Schema issues when appending from XY Event Layer
1051
08-17-2011 10:38 AM
RoyHewitt
1.  I have an excel table of GPS points that I'm importing into ArcMap with Make XY Event Layer.
2.  Next I'm copying features to disk temporarily to create an OID field.
3.  Then I'm clipping the points within my area of interest to disreguard any points where the GPS function shoot off a point in South America.
4.  Finally I'm appending the points to a shapefile for all of the camera points (we have 6 different cameras going into the field everyday)
The problem that i'm having is I can't get the schemas to match up from the clipped points.  I've copied down the schema by hand, gone in and altered the schema in the target dataset without any luck (the TEST parameter returns an error, and the NO TEST parameter leaves the fields empty).  With NO TEST selected, there are no drop downs for the fields in the target dataset indicating which fields might match up.
What can I do to get a proper schema to match up??
RoyHewitt
Simple fix:
Just run the model once without the append.  The schema will be inherited from the input table -- you can delete the points if you're running a batch import and want to start with a clean slate.
