Reverse Geocode inside a Parcel polygon?
7707
10
10-20-2014 09:16 AM
CameronBlandy
We have a cadastre polygon feature class. Some of the features have a Name associated with the lot (i.e. Neighbourhood Park). I would
like to be able to reverse geocode using  coordinates to find out which Park Name the coordinates fall in. I have tried the using the General – Single
Field style but it only geocodes to the centroid of the polygon if I am within the distance specified. I also tried using the Gazetteer style and that was a
little better but did not seem to work in a Composite Locator when combined with Street based locators. Maybe I need a custom style.
I am using 10.0 SP5.
I hope somebody is able to help me or point me in the correct direction.
Regards,
Cameron
MattFancher1
@ShanaBritt thanks for the reply! And sorry, because my previous post wasn't clear. The situation is this:  we have a web app that residents can use to request service from our city. They specify the location of the service request by dropping a pin on a map. Dropping a pin triggers a reverse geocode to get the "closest" address. The geocode service we call uses a locator with three reference layers:  address points, street centerlines, and park polygons. Park polygons are included as the POI type because we want any pin dropped within the park to be tied to the official park address. That works as expected. However, we have a few edge cases where residents drop pins outside the park, but the reverse geocode call still returns the park address. We think that's because the parks in the edge cases are very small, and their centroid is less than 25 meters from the perimeter of the park, which is the search tolerance for the POI centroid feature type. Hopefully that makes more sense. Is there a way to avoid returns from the park polygon centroids when pins are dropped outside the parks?
