Reverse Geocode inside a Parcel polygon?
7682
10
10-20-2014 09:16 AM
CameronBlandy
We have a cadastre polygon feature class. Some of the features have a Name associated with the lot (i.e. Neighbourhood Park). I would
like to be able to reverse geocode using  coordinates to find out which Park Name the coordinates fall in. I have tried the using the General – Single
Field style but it only geocodes to the centroid of the polygon if I am within the distance specified. I also tried using the Gazetteer style and that was a
little better but did not seem to work in a Composite Locator when combined with Street based locators. Maybe I need a custom style.
I am using 10.0 SP5.
I hope somebody is able to help me or point me in the correct direction.
Regards,
Cameron
CameronBlandy
Brad from ESRI gave me the solution so I am posting here for all users. Here it is:
Go to the locator style (%ArcgisInstallDirectory%\Locators) and open the General.lot.xml in a text editor (I would suggest Notepadd++).  Look for mapping_schema name="SingleField"t used here so t worry about that) in the XML file.  If you look in the XML just ” section.
If you comment this out, the locator will be built with polygons instead of points.  It will make the locator slower but will  work better for reverse geocoding.  You can comment this out by adding a “<!—“ before the first “<conversions>” tag and “-->” after the“</conversions>” tag like you see below:
<!--<conversions>
     <conversion>
           <mapping ase_ref="Shape">
                <method ref="calc_polygon_centroid">
                    <parameter>
                         <field_value ref="Shape" />
                    </parameter>
               </method>
          </mapping>
     </conversion>
</conversions>-->
After this you will need to re-create your locator (not rebuild).
CameronBlandy
<!--<conversions>
     <conversion>
                    <parameter>
                    </parameter>
               </method>
          </mapping>
     </conversion>
</conversions>-->
AndrewMilanes
What is the equivalent solution when using Pro?
BruceHarold
Esri Frequent Contributor
Hi the procedure is the same if you are using a Single Field style locator, its just the location of the style file in Pro has changed, by default it will be at:  C:\Program Files\ArcGIS\Pro\Resources\Locators
KadeChapman3
Is this still an option in ArcGIS Pro 3.3?
ShanaBritt
@KadeChapman3 This option is not available for locators that are built with the Create Locator tool or Create Feature Locator tool. The option was only available for locators built with the Create Address Locator tool in ArcMap or ArcGIS Pro 2.6 and earlier.
KadeChapman3
@ShanaBritt Is there a way to get the same functionality in ArcGIS Pro? I want to avoid a reverse geocode match being based on the nearest polygon centroid, but based on what polygon it is intersecting.
ShanaBritt
@KadeChapman3 The is no way in ArcGIS Pro to modify the locator template to return the polygon as you could with the classic locators in ArcMap that is referenced as the solution for the original question in this post.
-Shana
MattFancher1
@ShanaBritt We are bumping into an issue similar to what @KadeChapman3 describes. We want a reverse geocode to return a polygon result if the searched x/y is within the polygon. We do not want the reverse geocode to return results if it is outside the polygon, but within the search distance of the polygon centroid. Is there anything new or coming to Pro/Enterprise that would support that?
ShanaBritt
@MattFancher1 What type of polygon data is the locator built with? What does it represent? Which roles are used in the locator used for reverse geocoding?
There is nothing new in the latest release that supports returning a polygon as a geocode result.
