ReplaceDataSource not working in script
6817
10
07-20-2010 04:10 AM
ChristianHalsted
I am trying to write a script tool that will loop through all the disconnected layers in a map document and repoint them using the Layer.replaceDataSource function.  When I run the following 3 lines of code:
mxd = arcpy.mapping.MapDocument("CURRENT")
lyr = arcpy.mapping.ListBrokenDataSources(mxd)[0]
lyr.replaceDataSource(r"Database Connections\GISUSER on dep-eia1dbsop01.sde","SDE_WORKSPACE",r"Sample_Location",True)
from the Python Window within ArcGIS Desktop it works fine.  But when I put them in a .py file and try to run the script from ArcToolbox it seems to reconnect the file but then removes it from the map document.
HenkZwols
I'm having the same issue when running my python script.
It connects the layers fine, then immediately removes them.
Is this a known bug?
I have the same problem: after setting the source, the layer is removed from the TOC.
What's happening?
Greetings, Henk
