Reclassification precision error
965
04-20-2012 06:35 AM
MikeWissner
Hello All,
When running the Reclass tool within a larger model I received the following message:
To ensure a correct reclassification, edit ranges or use a different precision settings in the Reclassification dialog box.
The input raster maximum (-1.7976931348623157e+308) is out of range.
The reclass executes successfully, but I have not been able to figure out what exactly this error refers to. Could someone please enlighten me?
thanks, mike
BrentEdwards
Same issue here. The results seem fine, but I get the same "To ensure a correct reclassification, edit ranges or use a different precision settings in the Reclassification dialog box." message.
