Real Cool Stuff on Python
5030
12
10-29-2009 10:39 AM
TedCronin
So, far, the py window is pretty cool.  I type a little bit more here than with arcgisscripting, but really now, I think I will use this window over the command line window anyday even with the extra space ;).  Long Live the Python Window.  Now it doesn't beat Wing, but still pretty cool.
Should have tested this more in holistic.
TedCronin
I like we can now effectively put from ... import ... to use.
TedCronin
To facilitate the transfer of environment settings from one script to another and to save settings from one session to the next, settings can be saved to a file. ArcPy can then set its environments by loading a settings file.  This is pretty cool.  Awesome.
The only issue I have is why os.system, and not subprocess as part of the sample for calling the settings file.  Cool Nevertheless.
TedCronin
This was new at 9.3, but they are really cool.
TedCronin
Hi Ted,
Right, this is an enhancement at 9.4.  Less code, easier to understand.
At 9.3, you would have to use a while loop like so...
rows = gp.SearchCursor(myTable)
row = rows.next()
while row:
    print row.getValue("Rank")
    row = rows.next()
At 9.4, you can you use a for loop (you can also use the while loop approach if you desire)...
for row in arcpy.SearchCursor(myTable)
-Dave   😛
TedCronin
arcpy.ListFiles("*.zip")
[u'C:\\GIS\\94\\CopyHome.zip', u'C:\\GIS\\94\\dd.zip', u'C:\\GIS\\94\\ESRI_AGOL_StreetMap_Web_Kit.zip', u'C:\\GIS\\94\\Python25.zip', u'C:\\GIS\\94\\Screenshots.zip', u'C:\\GIS\\94\\Topology.zip']
Cool functionality, no more glob.
TedCronin
Applicable to py and models.  This is very, very handy, and very cool.
TedCronin
I get the raw string inserted when dragging a path from Catalog, thats pretty cool.  Thank you GP Team.
TedCronin
import arcpy as ap
#ap.env.workspace = r'C:\94_testing'
versionList = ap.ListVersions(r'Database Connections\ACR_GIS@sdemapper - Test Server.sde')
#versionList.remove ('dbo.DEFAULT')
#versionList.remove ('ACR_FINAL.Master')
versionList.sort()
for version in versionList:
print version
So, this is pretty cool, and it is a real list. So, I am assuming we can just feed this into a delete and delete a bunch of versions at once. Very Cool, indeed. 😛
StefanOffermann
Yeah, this is really really much more readable then in 9.3 Hooray! :cool:
