Re: Error in Spatial Join, when used in model Builder
342
10-07-2025 07:16 PM
DivyaSehgal
Hey Guys,
I have been doing some spatial analysis in arcgis, and I have made a model, one of the issues that I am facing is that I have a set of points on which I am doing a clustering and since I want to maintain the original id, using Add Join geoprocessing tool to join the clustering output back to the original table. After that I am doing a spatial join of another feature class(Lets call it feature class A) with clustered points(Feature class B ) to get the features in the vicinity, and finally filtering out that these two features should be within a day of each other. My issue is sometimes the spatial join is generating an output and other times leaving all the features from feature class B empty in the final join table, any possible solutions would be appreciated.
DuncanHornby
MVP Notable Contributor
If you have left any selections on or set environment settings such as processing extent then this could lead to the scenario you are experiencing. Without further details and a repeatable sample it will be difficult for anyone to nail down the issue. May be its a database issue, you say nothing about the source of your datasets, e.g are they hosted feature layers or a shapefile on onedrive... Very different
