raster to polyline creates squares
3956
02-24-2021 10:23 PM
JohannesBierer
The raster to polyline tool creates squares even with the option "SIMPLIFY". Is there a tool to create one line out of it this squares?
ArcGIS Desktop 10.6.1
DanPatterson
MVP Esteemed Contributor
Raster to Polyline (Conversion)—ArcGIS Pro | Documentation
What were the other parameters set to? eg background_value, minimum_dangle_length
What was the cell size? and was this originally a float raster converted to integer?
PS The last time I saw that using "Thin" seemed to work
Solved: How to create vector roads center lines from raste... - GeoNet, The Esri Community
... sort of retired...
DanPatterson
JohannesBierer
Hello,
the parameters are:
backgrVal = "ZERO"
dangleTolerance = 10
The cellsize is 1m, and yes it was a float raster converted to integer.
I will try thin tool, thank you for your help. I try to detect small ditches in flat wetlands.
