PythonWin
1690
6
01-25-2010 12:18 PM
TedCronin
MVP Alum
So, I just installed PythonWin.  It installed correctly, but did not place the Icon in the Python directory on the Start menu.  I can launch it successfully from the folder path C:\Python26\ArcGIS9.4\Lib\site-packages\pythonwin, but still it would be nice, and I presume an expectation by PythonWin users to see the icon in the Start menu.
JasonScheirer
Esri Alum
Is it under the ArcGIS 9.4's Python menu entry?
TedCronin
MVP Alum
Its not on the Start menu, under ArcGIS 94/python26.  It successfully installed, and it can be run, just not from the Start menu.
KimOllivier
Honored Contributor
I have an icon on the start menu at Programs>Python 2.6>Pythonwin. Of course I had to hack the Explorer filetypes to set the edit paths properly for .py files, but I have to do that in every training course since 9.1 for all the students.
I am still annoyed at the install hijacking the Python 2.6 install directory with another level under C:\Python26\ArcGIS9.4\ .  Yuck! a full stop in a directory path? How non-standard is that?
This apparently does not happen if Python 2.6 is already installed, so perhaps Python should be installed before ArcGIS, as a prerequisite just like .NET. Then apparently we get ArcGIS to respect the normal structure. I will give it a try to see if I can defeat the odd behaviour at Beta 2 by installing Python again first.
TedCronin
MVP Alum
Kim -
Have you tried installing when there is a 2.6.2 install present, by chance.  I agree 100%, it is a pain in the ass, that it is setup this way, I have a machine that had all my other non esri modules, packages, and it caused a lot of havoc.
JeffMoulds
There is an enhancement logged in our system to add PythonWin shortcuts to the Start Menu. For your records, the tracking number is NIM053578.
TedCronin
MVP Alum
Thank you Jeff
