Python script/expression for field calculator for converting bearings to directions?
19100
28
09-22-2016 10:03 AM
bobcostanza
I have a double field with bearings/azimuths (numbers) and I need them in letter directions: N, NE, NW,etc. I would like to calculate them in  a new field.  I have searched high and low for the code to use in the field calculator but I have failed to figure it out.
Bob
DanPatterson_Retired
Darren... just shift your dictionary by 45 degrees since N-ish is 315 to 45, E-ish 45 to 135
DarrenWiens2
Ahhh, yes that's right. Well, you get the idea.
BlakeTerhune
Yeah, I did the same thing
making digtize so much cleaner, since you can slice the 0-360 range anyway you like and the angle 'fits' in its correct position
rather than messing up the original script post.
Direction (one variant of many... wiki it for the others)
Cardinal   Degree range
N   348.75 - 11.25
NNE  11.25 - 33.75
NE   33.75 - 56.25
ENE  56.25 - 78.75
E    78.75 - 101.25
ESE 101.25 - 123.75
SE  123.75 - 146.25
SSE 146.25 - 168.75
S   168.75 - 191.25
SSW 191.25 - 213.75
SW  213.75 - 236.25
WSW 236.25 - 258.75
W   258.75 - 281.25
WNW 281.25 - 303.75
NW  303.75 - 326.25
NNW 326.25 - 348.75
import numpy as np
global a
global c
a = np.arange(11.25, 360., 22.5)
c = np.array(['N', 'NNE', 'NE', 'ENE', 'E', 'ESE', 'SE', 'SSE',
              'S', 'SSW', 'SW', 'WSW', 'W', 'WNW', 'NW', 'NNW', 'N'])
def compass(angle):
    """ test """
    return c[np.digitize([angle], a)]‍‍‍‍‍‍‍‍‍
Expression for the field calculator
compass(!Field_with_the_angles!)  # using the python processor of course
For general testing or for single entry use and testing.
angles = np.arange(0, 360, 20) #[0, 44, 46, 134, 136, 224, 226, 314, 316, 359]
    for i in angles:
        print("{} => {}".format(i, compass(i)))‍‍‍
Result
0 => ['N']
20 => ['NNE']
40 => ['NE']
60 => ['ENE']
80 => ['E']
100 => ['E']
120 => ['ESE']
140 => ['SE']
160 => ['SSE']
180 => ['S']
200 => ['SSW']
220 => ['SW']
240 => ['WSW']
260 => ['W']
280 => ['W']
300 => ['WNW']
320 => ['NW']
340 => ['NNW']
bobcostanza
I don't know what are appropriate responses for this new forum  but I want to thank you all for your help.  I should be able to give the scripts a test on Monday.  I do need to calculate NNE, SSW, WSW, etc.
It appears that the new forum is a collaborative effort between a bunch of people?  I'll try to read about it.
I am really surprised that my question was new.  I thought a half hour of Googling and I'd find how to do it.
Bob
DarrenWiens2
It depends what you were searching for. Does it ever work to search for a ready-made script that does exactly what you want? You really just need a "Python if statement" (or more likely, several), which produces endless useful search results explaining how to do what you need to do, if you look at the more general problem.
bobcostanza
Dan, I just got around to working with the script you provided.  Should your last expression from Sep 23, 2016 10:38 AM  work as is except for my field name with the angles?
make a text field to put the result in.... the !YourFieldNameWiththeAnglesGoesInTheExpression!
goes between the double ! marks.
bobcostanza
Oh, crap. I think I made it a number field!
Thanks Dan, I'll try again on Monday.
Bob
