Python Script Error:  System Resources Exceeded
784
12-31-2010 04:58 AM
JosephSheffield
I'm running a fairly complex python script, exported from Model Builder and customized.  The input feature class has about 5000 features, basically the script is loop to run the entire analysis on a single feature and then move on to the next feature.  The script will run until feature 94, then I get ERROR 999999:  Error executing function.   General Function failure System Resources Exceeded.
I've ran complex models before on large feature class, but never this large.  Is there a limit to the number of geoprocessing operations Arc 9.3.1 can do at one time?
ChrisSnyder
Honored Contributor
It would help if you posted your script. Be sure to use the code tag (# button) so the indentation will be preserved.
