Python in model builder...how do I output a table?
3941
8
08-22-2011 10:59 AM
SeanCook
Hello all. I am having trouble figuring out how to return a table from a python script in model builder. I want to take a table view in and output a recordset. I was hoping something like the below would work, but it does not.
table = arcpy.GetParameter(0)
result = table
optable = result.getOutput(0)
If anyone could tell me the magic line that will let me get the above to work, I would greatly appreciate it.
I do intend to modify the table later, but right now inputting and outputting an identical table would be a huge step forward.
Thanks in advance to whoever reads this!
DaleHoneycutt
See the help topic Setting script tool parameters. It appears you want a derived output parameter, so pay particular attention to the write-ups about derived output parameters.
SeanCook
For right now, I just want to take a table in, put a table out, and display it. I have read all the documentation, I just can't find anything that works. The getOuput seems to error because, perhaps, it is not the output of a tool. Ok, so....how do I assign a variable as an output?
Any advice on how to save my modified lists into a file I can output as a recordset will also be helpful, but is a problem for later.
KevinHibma
I'm not sure this is exactly what you want to do, but try this code:
import arcpy
inTable = arcpy.GetParameter(0)
arcpy.SetParameter(1, inTable)
Maybe I'm confused why you're casting something to something else? If you want to inspect the attributes of the featureclass you can do it the same if its features or a table (recordset). I assume you'll be using a search cursor to loop through the attributes?
And can you post a link to the doc where this isn't working? If you're using:
result = table
Result should be the result of a GP operation....
result = arcpy.TableToTable_conversion('inputTable','in_memory','outputTable)
SeanCook
import arcpy
result = table
Ok, I am working with arcserver, and my only is to be able to do whatever I want with a table....preferably by using a search cursor to feed it into lists, modify the values, and then output a recordset which can be displayed in arcserver.
I will play with what you've put up for a bit a post again. I really do appreciate the help.
How would you turn a list of lists into a recordset? Write it to a csv, then save that using table to table, then output that derived table?
I was casting something into something else because I couldn't figure out what the results method did.
KevinHibma
Ok, I am working with arcserver, and my only goal is to be able to do whatever I want with a table....preferably by using a search cursor to feed it into lists, modify the values, and then output a recordset which can be displayed in arcserver.
Right - I wouldn't worry about the conversion then...just use the cursor right off the input features. Do you thing, then write out the new table. Here's some untested code off the top of my head
import arcpy
inTable = arcpy.GetParameterAsText(0)
SearchRows = arcpy.SearchCursor(inTable)
outTable = r'in_memory/OuTable'
outRows = arcpy.InsertCursor(outTable)
for row in SearchRows:
        value1 = row.NAME
        value2 = row.TYPE
        value3 = row.SUPERFIELD
        singleOutRow = outRows.newRow()
        singleOutRow.outNAME = value1
        singleOutRow.outTYPE = value2
        singleOutRow.outSUPERFIELD = value3
        outRows.insertRow(singleOutRow)
arcpy.SetParameter(1, outTable)
SeanCook
import arcpy
        value1 = row.NAME
        value2 = row.TYPE
Well, I might want to transpose rows and fields, etc, not just modify values. I am going to be creating a substantially different table than what I am inputting. Also editing field names, deleting fields, adding fields, moving fields, etc. It's going to get extremely slow using arc tools.
SeanCook
Kevin, you have been a huge help. I got it working for now....thanks!
SumitSharma
Hi khibma,
I have a geoprocessing service �??A�?� that returns output as GPRecordset.   Now I want to use the returned recordset  as input into another GP service �??B�?� that is created using python script.
I am using following to set input type inside the python script for service �??B�?�:
Arcpy.GetParameter(0)
And from Script side (Gp properties) I am setting input type  �??Recordset�?� as parameter type. Attached is the screenshot.
But when I try to run the service �??B�?�, it fails as it is not allowing passing record set as input.
The workflow I am trying to accomplish is generating tables from GP service �??A�?� and passing that tables (as recordset) to GP service �??B�?� for reporting. I am struggling with passing the data to GP service �??B�?�.
I would highly appreciate any help in this regard.
FYI: Working with ARCGIS Server 10.0.
Sumit
