Python: ERROR 000728: Field LINK_TO does not exist within table
1983
06-25-2010 01:59 PM
by Anonymous User
Not applicable
Original User: BrendanM
Hello
I am writing a Python script that checks if a field exists in the table, adds the field if it doesn't and then calculates a value for the field. I receive an error message telling me that the field does not exist in the CalculateField function.
4 things:
1) Both Check A and Check B below tell me that the field is in the table.
2) If I remove the table from ArcMap once the field has been added and then add it back, I am still told that the field does not exist.
3) If I close ArcMap and re-open then the field is recognized and the script continues.
4) If I add a field in a similar manner to a shapefile attribute table, the field is recognized and the script completes.
Anyone have a solution, please? Thanks.
Brendan Magill
theFieldList = gp.ListFields(theBillingTable)
theFlag = 0
for eachField in theFieldList :
        if      str(eachField.Name) == "LINK_TO" :
                theFlag = 1
if      theFlag == 0 :
        gp.AddField_management(theBillingTable,"LINK_TO","TEXT",3)
                gp.AddMessage("Yes, the field is in the table")    #Check A
                LinkToFld = str(eachField.Name)
gp.AddMessage(LinkToFld)         #Check B
gp.CalculateField_management(theBillingTable,LinkToFld,"\"-\"","PYTHON")
ChrisMathers
Well you can condense this a bit which may solve the problem.
fields=[]
for field in the FieldList:
    fields.append(str(field.Name))
if "LINK_TO" not in fields:
    gp.AddField_management(theBillingTable,"LINK_TO"," TEXT",3)
    gp.AddMessage("Added the field to the table")
    LinkToFld = "LINK_TO"
else:
    gp.AddMessage("The field is already in the table")
