publish python script tool accessible in citrix published ArcMap
3457
08-16-2012 06:18 AM
by Anonymous User
Not applicable
Original User: jdross
I've created a tool with python and I'm trying to run it in ArcMap.  the tool works fine in ArcMap (or ArcCatalog) directly on the desktop but our user base accesses ArcMap using Citrix.  When I try to run it from Citrix, It has 3 parameters, a multivalue control that of type folder, an output location of type folder and an output file name that is just a string.  When I populate the controls and click run I get a Windows popup window that says
Windows cannot open this file:
File: toolbox.tbx
To open this file, Windows needs to know what program created it.  Windows can go online to look it up automatically, or you can manually select from a list of programs on your computer.
What do you want to do?
[radial button] Use the Web Service to find the appropriate program
[radial button] Select the program from a list
I am publishing ArcMap as a standalone application to the users.
I am on ArcGIS 9.3 SP1
Any help would be appreciated.
