Problem with Delete Field
1481
01-17-2011 06:43 AM
DanielDillard
Hi all,
I am attempting to delete fields from a result table of the ZoneStatisticsAsTable tool.
Here is the script in python:
import arcgisscripting
gp = arcgisscripting.create(9.3)
table = "C:\GISDATA\resultTable"
fields = gp.ListFields(resultTable)
for field in fields:
    if ((field.name != "BUILD_ID") and (field.name != "MAX")):
        gp.deletefield(table, field)
I get:
RuntimeError: Object: Error in executing tool.
I tried running the deleteField tool on the same table in the command line in ArcMap and got an error saying the table does not exist or is not supported.
I am able to manually delete fields on this table in ArcMap.
At this point I am going to find another way to accomplish my goal.  I am just curious as to why this isn't working.
DanPatterson_Retired
is incorrect, it must be
table = r"C:\GISDATA\resultTable"
or
table = "C:\\GISDATA\\resultTable"
or
table = "C:/GISDATA/resultTable"
and I suspect that a file extension is also needed
ColinZwicker
I think you will also then need to pass that to the list fields
fields = gp.ListFields(table)
instead of
note: if that table is a shapefile attempting to delete a required field (e.g., FID) should also fail.
Well after 6 years I doubt he care... and just incase anyone forgets to use raw string formatting when using python, here is what happens
>>> print(table)
esultTable
No wonder the table couldn't be found
