Problem with ArcToolBox in ArcGis 10.1
1512
06-09-2014 08:52 AM
Jesus_ADiaz_S
[ATTACH=CONFIG]34451[/ATTACH]
When I open a tool in ArcToolbox, it is not showing anything, and ArcGIS installed several times, and I have the same problem, what can I do?;
thank you very much
Jesus_ADiaz_S
Each time you upgrade ArcGIS a new folder is created in your login directory so you lose your old personal toolboxes until you move them to the new directory.
Kim Ollivier (EADP101)
Thanks for your answer, but I found the solution to this problem: it's a problem related to the windows 7 user profile.
Best regards
KimOllivier
Honored Contributor
Jesus_ADiaz_S
Best regards
