Populating a field in a points layer with polygon number where the point is located
1259
08-04-2010 11:29 AM
JasonWinoker
I would like to populate a field which I added to a points layer with the number of a polygon layer in which the point is located.  For example, the points are manholes in a County.  The polygons are sections (with unique numbers).  I would like to populate a field in the manholes layer with the appropriate number from the sections.  I think that I will have to do a select by location-type operation, but I am unsure what to do from there.  I am sure that there is a simple, but...
I appreciate your help/input.
Jason
BBicking1
Jason
Hi Jason,
see if this workflow in MBldr will get you what you want:
Intersect ManHoles points w/Section polies
AddField 'ManHoleInSection'
CalculateField ->in the expression you assign the section value from the field that holds it to the 'ManHoleInSection' field.
Barbara Bicking
DanLee
by Esri Regular Contributor
You may also use Spatial Join tool (Analysis toolbox - Overlay toolset):
- Target Featueres = manholes
- Join Features = sections
- For the Field Map of Join Features, you can keep the fields you want from the sections and the manholes, and remove other fields.
- Match Option = INTERSECT
You should get a new output with the desired fields. Spatial Join tool combines the processes of selecting by location (you were on the right track), add field, and calculate field in one shot - a powerful tool!
Thanks.
RickWahl
In a similar project, I've used a spatial join to a set of points where the polygon number matches what I want the point number to be 95% of the time.  Because of this I need a script to assign the polygon number from the spatial join output points layer to a field on the original points attribute table.
I've joined the output of the spatial join to the original points layer.  Does anyone have a good approach to a field calculate to assign the new number to the original field only if the original field is empty?
