Hi all,
The concept you are discussing is aggregation of individual features (points, lines, polygons) into polygons - part of generalization. The geoprocessing tool, Aggregate Polygons, was added in ArcGIS 9.2 (Data Management - Generalization); and the geoprocessing tool, Aggreagte Points, was added in ArcGIS 10. Both tools are now in Cartography - Generalization toolbox/toolset; and they require ArcInfo license. You can set the aggregation distance to control the output distance - a very large value would result in a convex shape; reducing the value would make the shape concave.
If you don't have ArcGIS 10, but you have 9.2 or 9.3 with an ArcInfo licensing, what Thomas described is a pretty good workaround (with 3D Analyst). You can also try these steps to get a close result:
- Run Buffer on the point features with a small buffer distance to create polygons from points. You can see this as if you have make your points "grown" in size.
- Run Simplify Polygon on the buffer polygons with simplification distance = 1/3 of the buffer distance to reduce the number of vertices for better performance in the next step.
- Run Aggregate Polygons with a desired distance to combine the polygons. The distance should be the value that you need to aggregate points minus 2 x buffer distance.
- Run Buffer on the aggregated polygons with a negative value of the buffer distance you used. This is to "shrink" the shape back to be tight to the input points.
Hope this helps.
Regards.
