Overwrite geoprocessing output
7257
11
08-03-2010 07:35 AM
HarutyunShahumyan
Hi. I couldn't find any solution to the below described problem in the forum. Please let me know if there is a such thread or if you know how to solve it.
I have checked the "Overwrite the output of geoprocessing operations" in the Tools->Options->General window in ArcMAP 9.3.1. But when I am runing the same model second time, I am getting an error message: ERROR 000210: Cannot create output...
If I am manually removing the output files generated from the first run, the model works fine. But again for the next run it gives the same error. It seems that the "Overwrite the output of geoprocessing operations"  parameter is not haveing any influence.
Please let me know if you have any idea what is wrong here.
Thanks in advance.
CarmichaelEllis1
Still trying to wrap my head around it. Can you give an example of a situation where this should not be the case?
DanPatterson_Retired
Since this thrr3ead is long demised, perhaps you could start a new thread and pose a question that conveys your situation and why you are interested in an answer and what you have tried and the results you found
