overlapping polygons
4949
03-15-2015 10:07 PM
LeslieJawili
how can i edit overlapping polygons in a fastest way since i have a lot of polygon data to adjust.
thank you.
Tags (1)
DarrenWiens2
What exactly are you trying to achieve? Eliminate the overlaps?
DEAF_PROBERT_68
Honored Contributor
I would export your polygons to geodatabase first and have the polygon as a backup..  Once you export it to geodatabase then add the topology and that should help you find the overlaps....
To learn about it go here...ArcGIS Help 10.1
LeslieJawili
thank you
StevenGraf1
You could use the Integrate tool.  You specify an input and a distance and it will move all polygons together if they are within the tolerance.
This tool may change the outline of your polygons significantly if you set the tolerance too high.
Here is the link to the tool.
ArcGIS Help 10.1
Steven
