Output name to be the same as the input name (in a new folder) after processing
5275
09-01-2015 07:42 AM
ErtTre
I was following this simple example from ESRI (ArcGIS Desktop 😞
import arcpy
from arcpy import env
import os
# The workspace environment needs to be set before ListFeatureClasses
# to identify which workspace the list will be based on
env.workspace = "c:/data"
out_workspace = "c:/data/results/"
clip_features = "c:/data/testarea/boundary.shp"
# Loop through a list of feature classes in the workspace
for fc in arcpy.ListFeatureClasses():
  # Set the output name to be the same as the input name, and
  # locate in the 'out_workspace' workspace
  output = os.path.join(out_workspace, fc)
  # Clip each input feature class in the list
  arcpy.Clip_analysis(fc, clip_features, output, 0.1)
I would like to run a very similar code with "Identity_analysis", however, I receive an error message when run my code, as it wants to create only one shapefile rather many with the same name(s)  as the input file(s). Here is the code. It generates only one file " identity_country.shp" and than gives me an error msg that the file already exist.
import arcpy
import os
dirpath = r'C:\reggie\stat\spatial'
arcpy.env.workspace = dirpath
#set local parameters
identity_feature = r'C:\reggie\stat\GIS_stats\country.shp'
out_workspace = r'C:\reggie\stat\spatial\identity_country'
for fc in arcpy.ListFeatureClasses("*"):
     arcpy.Identity_analysis(fc, identity_feature, output, "ALL", "", "NO_RELATIONSHIPS")
Tags (3)
FreddieGibson
Honored Contributor
Does your output shapefile already exists in your output folder? If yes, then you would need to set the overwrite property to True or use python logic to check if the output shapefile exists and delete it if does prior to calling the tool that will generate it. I've shown two options for this below.
# ## OPTION A ## #
import arcpy
from os import path
arcpy.env.workspace = r"C:\reggie\stats\spatial"
idFeat = r""
outWS  = r""
    output = path.join(outWS, fc)
    arcpy.analysis.Identity(fc, idFeat, output, relationship="NO_RELATIONSHIPS")
# ## OPTION B ## #
import arcpy
from os import path
idFeat = r""
outWS  = r""
    if arcpy.Exists(output):
        arcpy.management.Delete(output)
FreddieGibson
Honored Contributor
# ## OPTION A ## #
import arcpy
from os import path
idFeat = r""
outWS  = r""
# ## OPTION B ## #
import arcpy
from os import path
idFeat = r""
outWS  = r""
ErtTre
Hi Freddie,
Both worked like charm, million thanks!
Additional Q - as the input vector contains many polygons while the identify feature has only one polygon, however, when the identify feature crosses the input feature I receive two or more readings (with the same FID) . See it below:
Could I set up the code in a way, that the input polygon is either and only in or out of the identify feature but not in both?
