On-demand geoprocessing
1117
02-14-2023 06:07 PM
FlorentinoBernalJr
Hello everyone,
I wanted to check if anyone has had experience running any geoprocessing tool on-demand using Oracle and ArcGIS Pro. So my scenario is this (this is the simplified and most relevant version):
  1. A user enters data (which includes an address component) into a front-facing application
  2. User clicks a "Submit" button
  3. Data ends up going to an Oracle table
  4. Data is supposed to be processed with a geoprocessing tool
  5. Geoprocessing tool then stores the result back into another Oracle table
  6. User is able to see the result within the front-facing application
I already built the geoprocessing tool needed to process the spatial data using a model and can run it manually and it behaves as expected. But my question is, is there a way for the tool to automatically detect new records in the Oracle table in step 3 so that it can run by itself without my direct intervention?
I'm open to ideas and would very much appreciate your input!
DavidPike
MVP Notable Contributor
Look into database 'triggers'.  What's the geoprocessing tool doing?  If the GP tool functionality can be done using Oracle spatial methods you could just create a database view which would be relatively simpler.
FlorentinoBernalJr
Hi David,
The tool calculates different types of district areas in which an address falls, and the 5 nearest service locations for said address. In addition to that, it also performs a join to capture other attributes from a different table before storing the result back into Oracle.
