Null Values with Extract Multi Values to Points
17498
23
09-21-2011 07:47 AM
MichaelWhitby1
When I use the Extract Multi Values to Points (Spatial Analyst) all my points receive a <null> value even though there are values in the rasters (DEM and aspect) where the points are located.
I tested the Extract Values to Points tool, and the results were correct; However I would like the values in the original point file and to do multiple rasters at once. Any suggestions on what might be wrong?
BrianEddy
Thanks Curtis.  I'll check it out....
Brian
DavidNagel
I didn't have any problem with this function using 10.3.1. Working on another computer with 10.5.1 I get numerous NULL values in my results where I got valid values previously. Extremely frustrating. I don't have any nulls in my rasters and the point file seems to be perfect. Using Extract Values to Points works fine on a single raster. Using Extract Multi Values to Points on the same single raster gives NULL values in a number of records. Just adding to the thread here in case anyone else needs validation that this program has a problem.
Dirk
I was getting the same issue. Numerous things stated in this thread helped:
- ensure the input point layer and raster are switched off when you run the tool (switch off the table too if you have it on)
- ensure the coordinate systems are aligned
One additional thing that was a problem in my case:
- Ensure you clear any selections before running the tool.
JosephRigley
Still a problem at 10.8 over a decade later. In my case, I couldn't get Extract Values to Points to work either, it would also only produce null values.
Luckily I was able to successfully run the tools in Pro.
